Hi Guys ive gotta replace both outer CV boots is there any thing i should look out for when pulling off the front hubs.
Or any tricks i should know b4 attempting to do it ?
Outter CV boots
Outter CV boots
Terrano TD 2.7 and a ssangyong Rexton
Re: Outter CV boots
a friend used this guide when doing his it seemed to help.
Code: Select all
http://www.4x4wire.com/isuzu/tech/CVboots/- Suza
Re: Outter CV boots
Pop the top ball joint off and life gets really easy
- mud_slinger
Re: Outter CV boots
remove the whole half shaft its easier. pull the whole hub off makes life easier. while the hub is off check the bottom ball joint cos to replace it the hub has to come off anyways
needs more curry
0272593533
0272593533
- george.ene
- Driver/Navigator
Re: Outter CV boots
Have a look at youtube. The guy goes to take a whole side off (tie rod, locker, cv, brakes).
http://www.youtube.com/watch?v=k5xykfZJ ... sults_main
I've just replaced it in mine. if you have issues with your lockers let me know.
Re: Outter CV boots
Suza wrote:Pop the top ball joint off and life gets really easy
x2
