Outter CV boots
Posted: Mon Apr 09, 2012 5:34 pm
by long
Hi Guys ive gotta replace both outer CV boots is there any thing i should look out for when pulling off the front hubs.
Or any tricks i should know b4 attempting to do it ?
Re: Outter CV boots
Posted: Mon Apr 09, 2012 5:57 pm
by sprey
a friend used this guide when doing his it seemed to help.
Code: Select all
http://www.4x4wire.com/isuzu/tech/CVboots/
Re: Outter CV boots
Posted: Mon Apr 09, 2012 6:04 pm
by Suza
Pop the top ball joint off and life gets really easy
Re: Outter CV boots
Posted: Tue Apr 10, 2012 6:08 pm
by mud_slinger
remove the whole half shaft its easier. pull the whole hub off makes life easier. while the hub is off check the bottom ball joint cos to replace it the hub has to come off anyways
Re: Outter CV boots
Posted: Fri Nov 09, 2012 10:40 am
by george.ene
Have a look at youtube. The guy goes to take a whole side off (tie rod, locker, cv, brakes).
http://www.youtube.com/watch?v=k5xykfZJ ... sults_mainI've just replaced it in mine. if you have issues with your lockers let me know.
Re: Outter CV boots
Posted: Fri Nov 09, 2012 12:54 pm
by FORGE1
Suza wrote:Pop the top ball joint off and life gets really easy
x2
