Fabricators in Auckland?
- LT1-62
- Bush Crasher
Anybody know of any reputable fabricators in the Auckland area? Semi contemplating springing over my truck and was wondering who to go to regarding this mod, looking for someone who is competent, realistically priced, and can live up to deadlines...Thanks in advance, Matt.
yes, all the gears, high steer kit etc.. spring plates are a DIY thing.. if you need a hand, i have 2 welders and a big shed... Will email a mate for a price on the gears..
http://community.webshots.com/album/552140651QxHfNe
just realised your kit is different to mine.. i needed a new pitman arm.. (basically a 60 series one) i'll let you know how much.. Mine cost me $1200 all up including mounts and pitman arm..
http://72.34.32.141/~snakerac/product_info.php?cPath=2_88_100&products_id=438&osCsid=cf0a0e4e67fbb23de9f0b2e72d7cac6d
I might have alot cheaper option.... I'm not certain I think my hilux hi-steer arms might fit :scratch: if they do they have a similar lift to the snake ones and I can make the tie-rod and drag link to fit $900 for the whole kit n cabodle
http://www.offroadexpress.co.nz/modules.php?set_albumName=Project-Lemon&op=modload&name=Gallery&file=index&include=view_album.php&page=2
I have a set all made up , another option if you were keen is I can make tierods to take your current balljoints if you wanted to save some more money
Just another option
If your keen let me know and I'll track down a cruiser to see if they fit
Cheers Reece
Just another option
Cheers Reece
- LT1-62
- Bush Crasher
Sounds good Reece. Id certainly be interested in knowing if these will fit my truck since the price is definitely right. I am not totally committed to the idea of doing an SOA yet though as I am also considering dropping a similar amount of cash on a full set of superior drop shackles, and cleaning up the underneath by doing a U-bolt flip in the rear, and buying some of Oldblue's recessed spring plates for the front. The main motivating factor for going SOA though is that with my current lift I cant get to the bumpstops because my 35"s rub, and the superior shackles will give me crazy droop but wont actually give me any more lift to prevent rubbing. It'd be nice to know which setup would give more flex...
- LT1-62
- Bush Crasher
De-Ranged wrote:Right I've been told hilux arms will fit .... in fact they are the same right up untill the 74 series cruisers, except for the LJ70 which had a backwards setup![]()
If your keen to go with these arms, let me know
Cheers Reece
Gday Reece
Keep me in mind, Im 75% keen but wont have any cash till I get back from a SI roady at the beginning of next month. Taking the truck for a snowboarding/4wding tour of the south, so hopefully will have a better idea of what Im after suspension wise after that anyway. Will be in touch, cher, Matt
