Safari Oil's
Posted: Tue Apr 10, 2012 8:28 am
by Suza
Hi All
I have just bought my first Safari. 1991 TD42 Manual LWB with PTO winch. Now I want to do a complete change of all fluids as I do this with all vehicles that I buy and this one has spent the last 2 years parked up under some trees (Took 1.5 days to clean the paint work up).
What I need to know is what is the recomened oil spec for the motor,gear box and transfer, diffs (rear is LSD) and the PTO.
Re: Safari Oil's
Posted: Tue Apr 10, 2012 9:03 am
by Sadam_Husain
the pto is real thick 680 grade, I had to use a sludge gun to refill the Saf winch on my truck
http://www.adl.co.nz/Parts/40293/
Re: Safari Oil's
Posted: Tue Apr 10, 2012 5:56 pm
by Dak
BP Vanellus C4 for the engine is what I use, not sure if they still make it though, hope you are feeling rich to, the engine holds about 10 litres with both filters done.
Patrol Y60 4x4, TD42 Diesel (1988-1998)
CRANKCASE
CASTROL GTX PROFESSIONAL 15W-40
Service Refill Capacity: 8.0, 9.2* Litres.
MANUAL TRANSMISSION
CASTROL VMX 80
Service Refill Capacity: 3.9 Litres.
AUTOMATIC TRANSMISSION
ATF DEX III
Service Refill Capacity: 11.8, 8.5 Litres.
See note 13 below.
DIFFERENTIAL
CASTROL LSX 85W-140
Service Refill Capacity: 2.1 Litres.
See notes 114, 15, 43 below.
POWER STEERING
ATF DEX III
4WD TRANSFER
CASTROL VMX 80
Service Refill Capacity: 2.2 Litres.
See note 90 below.
4WD DIFFERENTIAL
CASTROL EPX 80W-90
or CASTROL SYNTRAX 75W-90
Service Refill Capacity: 5.4 Litres.
See note 44 below.
NOTES
Includes Oil Filter
13
Dry fill capacity shown, fill only to full mark.
15
Rear differential.
43
Pick-up and Cab/Chassis models with leaf-spring suspension, 4.7 litres.
44
Pick-up and Cab/Chassis models with leaf-spring suspension, 4.3 litres.
90
Some models use ATF DEX III. When changing or topping-up, replace with same type fluid.
114
If fitted with non-LSD type differential, use CASTROL EPX 80W-90 or CASTROL SYNTRAX 75W-90. For models with electric diff-lock, use CASTROL EPX 80W-90 or CASTROL SYNTRAX 75W-90, 3.0 litres.
Re: Safari Oil's
Posted: Tue Apr 10, 2012 6:33 pm
by Swamped
I use the stuff from the castrol lube guide...see above. Castrol Tection? global es 15w-40 is good in the engine. Been running that for the past 4-5 services.
Mobil Delvac was the best in my experience but it seems to be getting more and more pricey.
Tried sinopec 15w-40 in a GQ a while ago and it was shit. Was thin like water after 3 months of daily town driving to work and back. Won't touch it again.
Re: Safari Oil's
Posted: Tue Apr 10, 2012 9:49 pm
by crazyclark31
i run caltex delo 400 in motor.ryco filters. can't fault either. castrol oils everywere else. in th pto i use the moreys oil satabliser.(the thick stuff in the red bottle)
Re: Safari Oil's
Posted: Tue Apr 10, 2012 10:40 pm
by tweake
if the pto winch is worm drive then need to use the proper oil.
moreys make a range of oils for worm drives and its same price as engine oil.
Re: Safari Oil's
Posted: Sat Apr 14, 2012 10:40 pm
by Suza
Cheers for the help, got the front half of the Safari and the coolant done today back half tommorrow and bolting in a 3rd row of seats
