As per the title, I'm after a pair of 40-50mm lifted rear springs to suit '92 Terrano.
Prefer Christchurch area. Though I'd ask around first before going to Chamberlains.
Cheers, Rhys.
Terrano lift springs wanted
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
- tomsoffroad
- Flopsie
Re: Terrano lift springs wanted
Try Autolign
Yeah might give them a go if no private sales come up (being a real tin arse at the moment
Cheers!
Cheers!
I used Jeep grand c front springs in mine all you have to do is cut the pigs tail off them n they got in no probs at all.
Another option is using Ford F150 front coils as well.
You can get both types a hell of a lot cheaper than buy new
Terrano TD 2.7 and a ssangyong Rexton
If your still looking I have a set of Terrano II/Mistral standard springs, they can be modified by a Christchurch crowd to be taller, I forget specifically who but could look into it, assuming the springs are the same size... That said I just picked up a pair of Dobi's from Autolign for under $200.
cpjfox wrote: ... That said I just picked up a pair of Dobi's from Autolign for under $200.
Definately sounds the go! Might check them out (once I've got clearance from the boss)
- Shuttle Queen
Try these.....
http://cobrasprings.co.nz/catalogue/nis ... rrano/5926
I purchased mine through a guy selling them on TradeMe from this guy...
http://www.trademe.co.nz/Members/Listin ... er=3691434
You can reach him on 02102583332 or mr.svo@live.com
I'm very happy with the springs I got. Heavy duty 50mm lifted. Perfect fit.
- mayhem1982
i have some 0220702748
- mayhem1982
ok turns out they arent lift springs, they are out of a bighorn. sits slightly higher than my mates 50mm lift springs
