WTD ln130 or kzn130 auto nsw lever
jonossiksilvia
Post by jonossiksilvia »
hi people.
after the lever that is attached to the nsw on an auto box
must be off of a ln130 or kzn130
part is the 1 with the red dot on it
cheers john
part with red dot on it
jonossiksilvia
Re: WTD ln130 or kzn130 auto nsw lever
Bump. Someone must have a stuffed auto or an auto lying around from a conversion. From the above models
muddyhilux
Post by muddyhilux »
i just dumped an auto the other week after it crapped out,sure i through this part as well but will double check for you mate
jonossiksilvia
sweet let me know how ya get on
muddyhilux
sorry mate,just had a hunt and nothing to be found.not the best option but could you make 1 up?might be the only way till you find one
madlux
Post by madlux »
got a spare box from a 961kz think the box is the same just the transercase is on the opp side. got any diamentions, they might be the same... mine reads 105 from bolt center to pin center. hope that helps. cheers
jonossiksilvia
muddyhilux wrote:sorry mate,just had a hunt and nothing to be found.not the best option but could you make 1 up?might be the only way till you find one
cheers for looking mate
jonossiksilvia
madlux wrote:got a spare box from a 961kz think the box is the same just the transercase is on the opp side. got any diamentions, they might be the same... mine reads 105 from bolt center to pin center. hope that helps. cheers
the kzn185 levers are different.
thanks anyway
