Adjustable panhard rods for 80 series
brakes-shocks-lockers-etc
hippy_
Post by hippy_ »
Been looking into this for sometime now.
Whats a good brand to get??
And where/who sells that brand??
Or is this a good brand???............ http://www.trademe.co.nz/Browse/Listing ... =465825876
rokhound
Re: Adjustable panhard rods for 80 series
Post by rokhound »
But why? If you have lifted the truck, then make a new/alter the existing panhard to the correct length. Unless you are planing on changing the rig again, this seems like a lot of unecessary expense.
mudlva
Post by mudlva »
rokhound wrote:But why? If you have lifted the truck, then make a new/alter the existing panhard to the correct length. Unless you are planing on changing the rig again, this seems like a lot of unecessary expense.
Would cutting and welding your panhard rod be legal on a road legel
Dont know so just asking
hippy_
Post by hippy_ »
Totally unsure if that is legal, but Im sure it could be done.
Im unsure of what length the panhard rods should be for the lift I have. Also if and when I get to old to jump in it at its current height, I can drop it down and then just winded in the rods to suit. Saves having to cut and weld again etc......
Keep the idea's/opinions coming.
tallsam66
Post by tallsam66 »
Im assuming you have lifted your truck & thats why you need a longer panhard.
The best way to go is to lengthen mount so as to retain the factory geometry ,you want it to be almost parallel to the diff , this way it will handle better on & off road.Just making panhard longer means the back will tend to kind of kick out & wobble a little under cornering sometimes.
hippy_
Post by hippy_ »
tallsam66 wrote:Im assuming you have lifted your truck & thats why you need a longer panhard.
Hadnt thought of doing it that way....... Its got 100mm spring lift. Thanks for the idea. 8) 8)
KIWI_TERRANO
Post by KIWI_TERRANO »
Or getting diff mount lifted helps it drive better to compared to lowering it on chassie is what ive been informed
rokhound
Post by rokhound »
Do that on the rear axle though. If you alter the front panhard and not the drag link you will induce bump steer. The panhard and the draglink have to be in the same plane and of similar length to maintain steering geometry.
Rear end, no sweat.
Bulletproof
Post by Bulletproof »
rokhound wrote: The panhard and the draglink have to be in the same plane and of similar length to maintain steering geometry.
Rokhound is right they must be on the same plane.
On my hilux I cut and joined a panhard rod to make it shorter. I found a solid rod that was a press fit to go inside the panhard rod across the join and then dowled both ends. The certifier was completely happy. It is better off tig welded rather than mig
Because you are lengthening the rod you would be better to join 2 rods rather than put a spacer in
Cheers Richard
Never say die, up man and try
tallsam66
Post by tallsam66 »
I was only thinking of the rear end ...be very careful if you tweek the front end.
Cheers Richard
mudlva
Post by mudlva »
try ARB for an adjustable PH rod as altering mounts will take the arm out of palarrel with the steering link
something to thing about as when you do adjust the rod lenght ensure the the link arm is extended by the same amount and this can be found by the lenght difference from the standard PH rod .
if you dont you may find the steering box may start binding at full lock and this may cause earlier failure of the box itself and may even put undue stress onto the chassis mounts behind the sterring box creating spliting and cracking
worth a thought
hippy_
Post by hippy_ »
Now Im totally unsure of which direction to head........ Hahaha. All good tho.. Thanks for the thoughts and idea's. Now its thinking time......
DEATH_INC
Post by DEATH_INC »
We've supplied adjustable rods for one of these. I'll have to double check, pretty sure they were from nolathane.
