Turning Fuel Down on Mitsi Challenger
pruggerdore
Re: Turning Fuel Down on Mitsi Challenger
No idea sorry, but why?
what sort of pump does it have?
when does it blow smoke? ie full throttle only, part throttle etc.
2feral wrote:Blows it at full throttle which is normal ......
its NOT normal.
if its blowing smoke constantly it will fail WOF. if its a puff of smoke it should be fine and turning down fuel probably will not help much anyway.
it looks like its an EFI pump anyway so there may not be any max fuel screw.
i would check the egr is blocked off. they can stick open and cause black smoke.
otherwise, assuming air filters etc are all ok, i would guess your injectors need reconditioning.
2feral wrote:Blows it at full throttle which is NOT normal for a vehicle running correctly.
Get your injectors serviced, or have your motor tuned professionally
