4wd binding virbration
antsarooney
Post by antsarooney »
Hi guys , help really needed . I have a Ln65 with a rover 3.9ltr v8 in it . Right the problem is only when it's in 4wd it has a big virbration and feels like it's binding up to as it doesn't want to roll forward freely at all . Unlock the hubs and all's good . Help .
Smurf
Re: 4wd binding virbration
Post by Smurf »
are both diffs running the same ratio? if not they will bind up as you state
jj1959
Post by jj1959 »
All your wheels the same size????
antsarooney
Wheels all the same.
Have thought about diff ratio and that was probably the next step.
Thanks for help.
Smurf
Post by Smurf »
One other option is that your front diff has exploded and jammed up. worst case scenario though.
antsarooney
Have pulled front diff apart and all seems fine.
