Hi guys
My truck is tending to run a bit hot on the open road and I think it is due to all the mud inbetween the radiator fins. Hosing it out doesnt work as it is pretty much burnt on. I have tried mag wheel cleaner before washing it and that helped a little bit. I plan to remove it this weekend and try clean it properly.
What is the best method to get the mud out of it?
Thanks
Cleaning mud out of radiator fins
Re: Cleaning mud out of radiator fins
Soak it in a tub/bath for a week
Jerry wrote:Soak it in a tub/bath for a week
with some sugar soap or detergant in also
- Suza
Had my radiator out last night and found it full og seeds, thistles and mud.
Soaked it in an old bath over night and then hosed it out this morning and then blew it out with compressed air.
Bolted it back in
Bolted it back in
try using a liquid cleaner ie liquid dynamo or equivalent .spray it on then leave it to soak then rinse of .This was the shizz when we wanted to clean the mud off our m/bikes
I use a kiddies paddling pool, the ones shaped like a clam shell. Lucky me, I have several radiators and run them on a rotational basis i.e, one is soaking at all times. I find that if you pick it up out of the water and drop it in again once per day and change the water regularly, it does a awesome job.
Works for me.
Works for me.
sig wrote:try using a liquid cleaner ie liquid dynamo or equivalent .spray it on then leave it to soak then rinse of .This was the shizz when we wanted to clean the mud off our m/bikes
this stuff is the best, been using this method to clean m/bikes, mountain bikes, buggys etc and brings it to a nice shine after
pos nissan patrol
Ln106 single cab
Ln106 single cab
