4JB1 Boost Up
For all Isuzu related topics
mud_slinger
Re: 4JB1 Boost Up
Post by mud_slinger »
do the exhaust from the back of the turbo wind the boost up to 15 and tweak the fuel as well. run way better on 15 psi and the exhaust makes a big diff.
needs more curry
0272593533
GotFlex
Re: 4JB1 Boost Up
Post by GotFlex »
i have 2.5 exhaust, intercooled and 17psi goes sweet on 35s
sibainmud
Re: 4JB1 Boost Up
Post by sibainmud »
Drurban has a 2.5 system running 18 psi with no fuel tweaks and posted the readings from the new EGT gauge he fitted in the weekend. It is quite quick on 33's.
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=34&t=30103&start=15
Go for it.
Drurban
Re: 4JB1 Boost Up
Post by Drurban »
sibainmud wrote:Drurban has a 2.5 system running 18 psi with no fuel tweaks and posted the readings from the new EGT gauge he fitted in the weekend. It is quite quick on 33's.
Go for it.
As what sibainmud said I have 2.5" exhaust from turbo, wound up boost to 18psi but on the motor way I can get it up to 20, I know it can go past that.
All my reading from the EGT gauge are in in the safe range, I had not even attempted to tweke fuel or intercooled it yet. Iam running almost worn 33" Khumo KL71's on the road, and it has a bit of grunt.
Cheers.
mud_slinger
Re: 4JB1 Boost Up
i wouldnt bother doing extractors or moving the intake, the costs and hassle is not worth it. its intercooled so that will help alot.
needs more curry
0272593533
rangimotors
Re: 4JB1 Boost Up
Post by rangimotors »
bought a bighorn mostly for towing a boat. Any pics of where people usually put the EGT probe? I'm thinking 2.5-2.75 exhaust a bit more boost and I think ill keep the viscous fan but add 2 electric fans to the front of the radiator and possibly add a small one to the intercooler. Any idea what sort of boost they run factory? Hopefully I'll get time to chuck in a boost gauge and EGT gauge this week
mud_slinger
Re: 4JB1 Boost Up
10-12 psi factory. i run 15 psi on mine. if you do alot of open road driving a fan is not really worth it on the intercooler, i gain 2 psi more on open rd due to intercooler. the viscous fans are quite good i have never overheated with just the viscous. do the dump pipe on from the back of the turbo. if you are feeling rich get the turbo made into a hybrid mine moves alot more air than it previously did
needs more curry
0272593533
rangimotors
Re: 4JB1 Boost Up
yea my turbo makes a samll wine, prob be ok for another 50,000k's but i may look into fitting a td05 or similar maybe an ihi would be better
Mattman
Re: 4JB1 Boost Up
Post by Mattman »
I did an egr delete and used the hole in the exhaust manifold that provided the egr feed.
Just fitted a boost gauge and I am seeing 15psi quite a bit on a stock setup.
Matt.
mud_slinger
Re: 4JB1 Boost Up
rangimotors wrote:yea my turbo makes a samll wine, prob be ok for another 50,000k's but i may look into fitting a td05 or similar maybe an ihi would be better
most use the internals from a vf10. no other housings work. my turbo has a bigger front cover,compressor wheel and a larger exhaust housing
needs more curry
0272593533
rangimotors
Re: 4JB1 Boost Up
why do no other housings work? Because of a strange flange setup or something? I'm not expecting it to bolt up but it cant be that hard to modify the manifold or even build a new one to bolt up a standard t3 or t4 flange etc?
Return to “Isuzu”
