prado auto
prado auto
Have a 92 prado auto that just stopped driving was driving then stopped any ideas where to start looking motor still runs fine
Re: prado auto
Gidday,
No drive in any gear at all? Any loud bangs before it stopped driving?
Checked the trans fluid level? 4wd lever hasn't been knocked into Neutral by accident? Drive shafts look at good? Linkages to the gear selector all connected?
Re: prado auto
checked all that still no drive pulled auto and found oil pump drive gears stripped
Re: prado auto
Don't forget to flush the oil cooler lines going to the radiator in case they have bits in them if you are going to keep it as an auto.
Maurice
KZN185, 1KZTE running needing birthday
Re: prado auto
I know where you can get a trans in HB
Re: prado auto
crazee wrote:checked all that still no drive pulled auto and found oil pump drive gears stripped
Bugger....
