Extended Shackles Beam Axle hilux
Posted: Fri Apr 20, 2012 3:38 pm
by pradon35s
hey
just wanting to get some guys opinions on extended shackles in a beam axle lux front and rear..
or problems they cause etc
have had people say do it and people say don't..
I already have 2" lift springs but just want to gain a bit more height..
any advice appreciated. cheers
Re: Extended Shackles Beam Axle hilux
Posted: Fri Apr 20, 2012 6:12 pm
by 3VILC
I have also read as much info for them as against. I think it comes down to preference really (and the WOF man). Yes it does give you a bit more lift, and a bit more flex, but also introduces extra sideways movement of the axle on the road, and front diff will need caster plates to correct allignment.
But as opinions go, if I could afford/make a set I would use them, standard steering doesnt like going much higher than standard tho at least on my truck until I can sort out doing a drag link end flip or if i win lotta a x-over conversion
Posted: Sun Apr 22, 2012 9:18 am
by madlux
would like to know some more info about having them aswell.. cheers
Posted: Sun Apr 22, 2012 11:38 am
by Lynx
Youll have to correct pinion angles aswell
