2.8 turbo.
skux
2.8 turbo.
Post by skux »
Have 90% of info.
Can some who knows or done this please list everything i need of a 1989 2.4lt ?
I have turbo, both manifolds, pipes, Dump pipe.
Any other bits?
Cheers for help
Lynx
Re: 2.8 turbo.
Post by Lynx »
oil/water lines..
tweake
Re: 2.8 turbo.
Post by tweake »
turbo,
exhaust manifold (don't forget the bolts!)
oil feed and oil return pipes,
water pipes,
cross over pipe and hoses,
intake manifold,
injection lines (have to swap two of them to fit the intake manifold)
air filter to turbo tubing (depending on what vehicle its going in),
brace from turbo to oil cooler,
oil cooler/filter housing (unless you mod the turbo oil feed),
turbo dump pipe,
better if you can get the injection pump but not critical.
skux
Re: 2.8 turbo.
Post by skux »
tweake wrote:turbo,
water pipes,
intake manifold,
turbo dump pipe,
Cool cheers for that, I did read i only need the top half or something of injection pump? Is this right? I can get my hands on it when i work out what bit im un bolting lol, Cheers
tweake
Re: 2.8 turbo.
Post by tweake »
easier if you get the whole thing. i'm told that while it can be done the boost comp doesn't connect up perfectly tp the 3l pump, so its just easier to change the whole pump.
if you only winding the fuel up a small bit you can get away without the boost comp.
Smurf
Re: 2.8 turbo.
Post by Smurf »
Drain into sump for turbo oil drain?
tweake
Re: 2.8 turbo.
Post by tweake »
you can't take the drain off the 2.4. you have to make a completely new one on the 2.8.
