FOR SALE Jeep Grand Cherokee ZJ 3.5” Suspension Kit 93-98
Smurf
Post by Smurf »
Rough Country 3.5 inch Suspension lift kit.
Brand New in Box, never used. $1100 was $1200
Was bought with intention of fitting, (obviously) but owner has decide to go in a different direction with the Jeep.
It will be for sale soon too. :D
Description:
This 100% bolt-on kit from Rough Country has what you need for more clearance and off-road flex. This kit will give you increased ground clearance and room to fit up to 31” tires. Kit also replaces the stock control arms with stronger, tubular control arms. The stock front coil springs are moved to lift the rear.
Max Tire Size: 31 x 10.50
Vehicle Application:
1993 – 1998 Jeep Grand Cherokee ZJ, 6-Cyl
Kit Contains:
- Lifted front coil springs
- Front and rear lower control arms
- Front sway bar links
- Crossmember spacers
- Rear track bar bracket
- Front and rear Hydro 8000 shocks
Notes:
- Models equipped with CV style front driveshaft may result in driveshaft vibration. If this occurs, replacing the driveshaft, axle yoke and / or transfer case yoke will need to be performed to rid the vehicle of driveline vibration
- Stock front coil springs are moved to lift the rear
Smurf
Re: FOR SALE Jeep Grand Cherokee ZJ 3.5” Suspension Kit 93-9
Post by Smurf »
bump
Smurf
Post by Smurf »
shows part of kit
Smurf
Post by Smurf »
bump
Smurf
Post by Smurf »
bump
Smurf
Post by Smurf »
still for sale :-)
Smurf
Post by Smurf »
Still for sale
Smurf
Post by Smurf »
bump, price lowered
Smurf
Post by Smurf »
Bump
Smurf
Post by Smurf »
bump, still available
Smurf
Post by Smurf »
bump
Smurf
Post by Smurf »
bump
Smurf
Post by Smurf »
bump
Smurf
Post by Smurf »
jeep owners?
WRNGLR
Post by WRNGLR »
sorry dude got a TJ not much good to me , good luck tho
