I have a IFS ln61 surf and i want to put it on a single cab short wheelbase chassis so i have the solid front axle swap with out all the cutting and welding of leaf spring mounts.
is this a simple bolt up opperation??
if so then what is the chassis number that will match?
has this been done before? and if i have to move some body mounts then which mounts are wrong?
i have access to hoists and welding gear.
I appreciate any input... cheers
LN61 body swap To Single cab swb Chassis HELP!!!
Re: LN61 body swap To Single cab swb Chassis HELP!!!
Be a lot easier if you just bought a factory solid front axle surf.
yea tried that but live axle surfs are extremly expensive, i cant even find a bare live axle surf chassis for under $1500
if any one knows of a live axle surf chassis available please let me know!
Just need a bare chassis, i have diffs and are going to use custom leaf packs.
- KIWI_TERRANO
Uptomynutsinrut or is selling a couple i think in chch, have a search for beam axle surfs in for sale section on here
