Where to look for a 4.1 Hi Pinion?
Posted: Mon Apr 30, 2012 9:40 am
by Disconewhere
I'm thinking of fitting a Toyota Hi Pinion to the front of my Landrover, a bit stronger apparently but also it'll allow me to run the tierod higher for more clearance.
Can anyone point me in the direction of some info as to what model Prado or 80/100 Series would have had 4.1 ratios in them?
How common are 4.1 HPs? What are the chances for finding an 4.1 HP E Locker ? Any guesses at how much I'll have to spend to get my hands on one?
Mike
Re: Where to look for a 4.1 Hi Pinion?
Posted: Mon Apr 30, 2012 9:55 am
by keithal
pretty sure its the 80 series front diffs that are 4.1 high pinion
Posted: Mon Apr 30, 2012 10:29 am
by Disconewhere
Thanks Keithal,
It would seem from what I've read that all 80 series ratios are 4.1 whether petrol or diesel, is that correct?
Posted: Mon Apr 30, 2012 8:17 pm
by wjw
the 1KZ Prado's 91 - 94 have 4.1 ratio reverse hi pinion front diffs. Where are you? as I have what I think is the front 4.1 R&P from my old Prado in the garage, haven't had chance to work out Ratio or anything yet. Was going to stick it on trademe when Id do.
Posted: Mon Apr 30, 2012 9:20 pm
by Disconewhere
Hey wjw, I'm in Wellington, what do you reckon your R&P are worth?
Posted: Mon Apr 30, 2012 10:09 pm
by sig
petrol auto 80s are 3.7.I might know where a 4.1 high pinion head is .The guy is after a 9 inch cruiser lsd head as a swap
Posted: Mon Apr 30, 2012 10:34 pm
by Disconewhere
Sig, I don't have a cruiser lsd to swap but would your mate be interested in selling his hi pinion 4.1?
Posted: Tue May 01, 2012 7:28 am
by wjw
Disconewhere wrote:Hey wjw, I'm in Wellington, what do you reckon your R&P are worth?
Let me check what it is first
Posted: Wed May 02, 2012 9:42 am
by Disconewhere
Cool, let me know when you've had a look.
You seem to know a bit about Prados, Do you know if Prados had 4 pin carriers or where they all 2 pin? Any reason that I can't fit a 4 pin centre from a rear diff to a Hi Pinion?
Posted: Mon May 07, 2012 10:29 am
by FJ55
I have a spare,make me an offer im in Napier
