whats the best way to lift the safari
For all Nissan related topics
surf_tomo
Post by surf_tomo »
As per title, I want to lift my swb safari 2 inches. 4wdbits has a variety of different options and weights etc. Will i need both shockies and springs? What is the deal with spring spacers? Anything else I need to consider, and is it something I can do at home?
cheers, Tom.
Re: whats the best way to lift the safari
yes do , with 2'' or 50mm can be done at home you don't need to change panhard rods, hardest part holding the mass of the truck in the air to get the springs in on to the alxes
different sring rates apply to the mass you carry in the back or bullbar an winch on the front :D
zukmeista
Post by zukmeista »
You could use a hydraulic jack? :P
