Recovery Points / Hooks
borg
Post by borg »
A friend has a Disco and would like to come out on a few shiney trips. He does not have bullbars however has been given a towbar mount that should be OK for a rear recovery point however we are trying to figure out what to do with the ones in the front.
Attached to the left there is an eyelet and we have a spafe for the right side however these are standard and im not sure about their rating.
Regards
Andrew
Furgus
Post by Furgus »
Here's a link to what I did to mine
http://www.geocities.com/furgus72/disco/mods/disco-modifications.htm
If you need more help just ask
Furgus
If at first you don't succeed .... Get a bigger hammer!!
ramon
Post by ramon »
I mounted mine on the right front chassis rail,there was allready a hole in the bumper i just had to make it a bit bigger so i could fit a strop through. used it once on a ccvc driver training da and had no problems. :D
