I need to know if theres anyway of telling the difference between a W56 gearbox, and R150 and R151 by just looking at them on the floor? Do they have the codes stamped on the box anywere? Any help would be much appreciated. Cheers
isn't that second pic of a G52,that has the transfer gear lever next to the gear stick and on a w56 it is a separate transfer box from the gearbox, i have a w56 in my shed and it is the same as the first pic,
Is too, my bad, image fixed. the bolt pattern and the housing around t/case lever is different between W56 and R series as per images. w56 and G52 more comparable overall other than t/case lever position, can't believe I missed that
