may 5th -6th
chop
may 5th -6th
Post by chop »
Mucked around local today thinkn bombing range tomorrow
Built not brought
SP450andLE
Re: may 5th -6th
Post by SP450andLE »
chop wrote:Mucked around local today thinkn bombing range tomorrow
*Cough* that's illegal, and you probably shouldn't post about it on here *cough* :wink:
4wd related, I used brute force to bend the top alty mount on the Lada. Now the belt is pretty much perfectly straight :D
Also took the head off my Mini. Pretty casual day tbh :lol:
chop
Re: may 5th -6th
Post by chop »
Oh yes of coarse,im meant up the beach
Built not brought
89surf
Re: may 5th -6th
Post by 89surf »
went duck shooting got 49 ducks for the day
muddyplumber
Spring Free
Re: may 5th -6th
Post by muddyplumber »
fitted some wrx seats in the Mutant(zuk hybrid) did some wiring on the gauges....got a rebuilt Warn winch of tardme for 400bucks was a good buy :mrgreen:
worzel
Re: may 5th -6th
Post by worzel »
Fitted rocker shaft off spare truck got rid off that anoying tic when ideling so all good now
lincooln
Re: may 5th -6th
Post by lincooln »
cleaned and painted the gearbox for the Suzuki today. That is all.
Lubrication Specialist
Lubrication Engineers
zukmeista
Re: may 5th -6th
Post by zukmeista »
Pulled the sump off my suzuki and resealed it. Begone oil leaks :twisted:
chrome
Re: may 5th -6th
Post by chrome »
battery and glow plugs replaced, elbow into turbo was shot so that was replaced too, stripped off the rear bumper to start bar work and replaced viscous fan too
fark the windscreen wipers i say
DIRTY OLD HILUX
022 519 7700
bryandc3
Re: may 5th -6th
Post by bryandc3 »
went up thompsons in my zuki, got about half way down the te aroha and turned around and on the way up managed to shear off my left free wheeling up... also lost a wheel nut
lesson of the day= check all nuts before and after each trip
Re: may 5th -6th
spent about a million hours pulling apart and unseizeing and rebuilding hundreds of idlers and tensioners to swap out the farked alternator thats full of woodhill alternator killing shit then spent another million hours tracing out the arb compressor wiring testing everything untill I found everything was ok and the stoopid relay had died :x :x then fixed a pile of other small shit, cleaned the mud out of the radiator, checked all the fluids and pumped the tahs up all so I can take the truck out for a snotting tomorrow and then repeat the above process waterblasting it all down again fixing another pile of other shit :roll: :x
LOLYF
Re: may 5th -6th
Post by LOLYF »
Sadam_Husain wrote: woodhill alternator killing shit
We call that shit "grinding paste".. It likes to eat brakes to :lol:
Re: may 5th -6th
LOLYF wrote:We call that shit "grinding paste".. It likes to eat brakes to :lol:
haha yeah I wasnt in that hole for long and now I've got big pools of oil on the shed floor under the front pinion :x :lol:
I hope you copped a few dents and bashes on your truck it was looking far too shiney at the start :D
kbushnz
Re: may 5th -6th
Post by kbushnz »
Watched my Bro and Nephew compete at Karate comp this morning then put two new radius arms in the Prado....
And my GPS tracker / alarm arrived in the mail....($60 used off Trade me)
Will fit it next week....
Sunday its finish off the water temp gauge and replace the brake pads..
Not enough time to replace the wipers...(big job that one)
And help my eldest fix his Motorbike....
LOLYF
Re: may 5th -6th
Post by LOLYF »
Sadam_Husain wrote:I hope you copped a few dents and bashes on your truck it was looking far too shiney at the start :D
Sure did :oops:
The drivers side has a particularly large dent in the shape of a pine tree :lol:
ladeda
Re: may 5th -6th
Post by ladeda »
89surf wrote:went duck shooting got 49 ducks for the day
thats a blady good count. all that pluckin and guttin.... I dont envy you right now. :)
Hit the juice with a dozen mate on friday night.
Bit of preventitive maintance on the shitta for the snow season coming up. Did waterpump, thermostat and replaced all the wierd twist up lada hose clamps with better ones, started making up a holder for the thermo fan switch by welding bolt onto bit of pip to T into rad hose and would ya gess it, farken welder ran outa wire again f*#k F*#k f*#k. :evil: :evil:
work tomorow :cry:
SP450andLE
Re: may 5th -6th
Why don't you just put a manual switch in the cab?
Just look at the temp gauge, and if it's getting hot, switch the fan on and leave it on. Then if you come to some water, switch it off :D
That's what mine is like,a nd it's so damn simple, and works a treat 8)
SP450andLE
Re: may 5th -6th
Today I ground some rust off the Lada. Then painted over it. Fun stuff :lol:
Also figured out how to keep the bonnet up using a cable tie, and removed both the master cylinders. Guess I'll have to get round to getting some new ones sometime soon... :roll:
suzookyman
Re: may 5th -6th
Post by suzookyman »
Bugga! :evil: one number off 1st divsion! why was my 11 not a 7 !!!!.Oh well back to work :cry:
Weemsy
Re: may 5th -6th
Post by Weemsy »
got the hilux holding water & running
finish the exhaust & can try to tune it (350 chev on open headers too noisy inside the workshop) chuffed cuz the injection works :D
exhaust, handbrake & seat mounts and she's finished - i think
big thanks to clive, reece, noel & buzz for the work they have put in while i drink piss & give bad advice. :lol:
weemsy
ladeda
Re: may 5th -6th
Post by ladeda »
SP450andLE wrote:Why don't you just put a manual switch in the cab?
yea Ive got a switch in the cab to switch them off for water crossings.
I want the thermo switch so I dont have to keep checking the guage.
Besides its alwase eventually gona happen where you forget to turn them on and there goes the headgasket. :?
for something so simple to hookup can save alot of heatake :D
chop
Re: may 5th -6th
Post by chop »
Went to murawai with camel and split a trans cooler hose,bugger
Built not brought
Red90
Re: may 5th -6th
Post by Red90 »
Pulled a Suz out of the tuki Tuki. Had water flowing thru windows. "a little damp"
Testing a new 'lure' on their rods
SP450andLE
Re: may 5th -6th
ladeda wrote:yea Ive got a switch in the cab to switch them off for water crossings.
Hmm I guess so.
Then again, I'm sure that overheating was a factory option :lol:
rayndeb
Re: may 5th -6th
Post by rayndeb »
Got wof on Hilux after three trips back to 3 different inspectors at same place .First warrant on farm hack for 12 months :D
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Camel
Re: may 5th -6th
Post by Camel »
Yip , Went to Muriwai with Chop .. Did some of this ...
vtc and cruiser.jpg (15.87 KiB) Viewed 10715 times
Jokes, Was more like this
And just before we went home, Chop decided to do some planting..
AndI finished installing the new clutch on saturday arvo ..
Image (old one in photo)
This wasn't fun at all, I Don't know how some people do it on the floor / mid bush , crazy!
4WDbits
Re: may 5th -6th
Post by 4WDbits »
Went to Meremere and watched the short course racing.
wopass
Re: may 5th -6th
Post by wopass »
isnt 10 the limit?? or was there 5 of you shooting??
:wink:
89surf
Re: may 5th -6th
Post by 89surf »
25 each is the limit
:wink:
NJV6
Re: may 5th -6th
Post by NJV6 »
It vaires from area to area, dependant on where they eat the most!
