VX front wheel beering
red-devil
Post by red-devil »
Anyone in CHCH have a ****** big socket for the wheel beering nut, i think its a 54mm
i notice a small rumble and jacked the old girl up and found a little bit of play.
time to pull all the beerings out and replace them i feel. o i better do the wipes too. now who had those. :oops: :oops:
jono
tallsam66
Re: VX front wheel beering
Post by tallsam66 »
ive got 1 ...come grab it anytime
red-devil
Post by red-devil »
SWEET :P
i'll pm you for ur addy
pradon35s
Post by pradon35s »
can get away with using a flat punch or chisel and hammer if don't have a socket big enough, just tends to mark the nut a little..
wjw
Post by wjw »
You'll probably need a new lock tab ring for it. My front one was loose as the ring was stuffed, seems to be a common occurance :-(
Who knew Prados could fly?
Jungle
Post by Jungle »
Its a pretty good idea to replace the lock tab washer after a couple of goes. Once you've bent a tab over and then bent it back, the metal usually has stress cracks in it. With five tabs on them, you can usually get a couple of turns out of it without using the same tab twice.
It's one tab forward and one tab back.
Jungle
red-devil
Post by red-devil »
yea i was thinking about replacing them. time to head to mr yota and pick up a few.
also thingin i should replace all beering too :mrgreen:
nismo26
Post by nismo26 »
I think the wheel bearing kits from Wilsonbros have that locking tab in it.
wjw
Post by wjw »
If you go to Toyota, you can buy just the lock rings. Most other places only sell kits.
its a regular occurance doing wheel bearings
so I bought the over-sized socket thingy for them which goes into 3/8 drive ratchet
cheap as and a worthwhile tool to have in your kit
pretty sure one of the vendors on here sells them :mrgreen:
edit; found him :wink:
http://www.offroadexpress.co.nz/Forums/ ... 64&t=28018
bottom pic of very first post 8)
suzolla
Post by suzolla »
Cheers Skid,
Only got 2 or 3 left.
Tim
red-devil
Post by red-devil »
thats kool
i'll have a few more bit to sort out with suzolla to buy :P
