turbo issue
Posted: Sun May 06, 2012 10:13 pm
by mudlark
had my 12ht under heap of load for a long time today at the beach and noticed that now wat seams to be under higher boost there is a metallic sound coming from the turbo, dosnt seam to be lacking power, just little worried about it,
all my intake is fine and filter regurly cleaned and replaced
Re: turbo issue
Posted: Sun May 06, 2012 10:21 pm
by D1rtysurf
could be a slightly blocked oil feed, not giving quite enough oil or turbo on its way out, take intake side of turbo off and feel for play
Re: turbo issue
Posted: Mon May 07, 2012 7:46 am
by crazyclark31
yep id be doing that quick smart as the trubo could be about to shat itself. Could also be a pully squealing. or a small boost leak. Ours does that to and after rebuilding turbo found it to be a needle hole in boost gauge hose and the power steering pully on its way out
