Page 1 of 7
WOF Change?
Posted: Tue May 08, 2012 11:34 am
by DDAN
So today I head down to VTNZ to get a WOF last 7years she just flys through but today it failed. I was like oh ok what It fail on,and he said you need low volume cert for the tires and lift. I said that's how it came into the country i haven't changed a thing, I thought if he was going to pick anything out it would be the Methanol injection and front mount intercooler, but he didn't say anything about that!, so now I guess I have to go spend 400 dollars or so on cert, not really happy about that!!! So who can recommend some one in chch
Re: WOF Change?
Posted: Tue May 08, 2012 11:36 am
by juz
Wait 21 days and take it somewhere else.... :wink: :mrgreen:
Re: WOF Change?
Posted: Tue May 08, 2012 11:52 am
by Jerry
Re: WOF Change?
Posted: Tue May 08, 2012 12:01 pm
by DDAN
Thanks the guy put it all down on the computer so I guess every WOF guy would have it now I can't see how he can do me for bigger tires as on my door as you can read it as 16 inch tires in Japan and its only a 2 inch lift if that
Re: WOF Change?
Posted: Tue May 08, 2012 12:54 pm
by turoa
DDAN wrote:Thanks the guy put it all down on the computer so I guess every WOF guy would have it now I can't see how he can do me for bigger tires as on my door as you can read it as 16 inch tires in Japan and its only a 2 inch lift if that
if nothing is modified and only larger springs are put in then according to the virm it shouldnt need a cert. Its only when you start modifying shit that it does. Tyres can only be 5% larger than standard though so Id just throw some little tyres on and take it back 8)
Re: WOF Change?
Posted: Tue May 08, 2012 1:00 pm
by tallsam66
If i were you id go back & demand they do a cpl of things
1.. Tell you where in the VIRM manual it says you need a Low Volume cert for what is a standard vehicle.
2 If they still insist that your vehicle is no longer standard to produce some information that will confirm there stance.
Also as a matter of interest did they give you the warrant last time ....if they did ask why they didnt pick it up last time ..you pay good money for an accurate inspection & last time it wasnt ..so you should be entilted to a refund for the last inspection as it was poorly done.
Re: WOF Change?
Posted: Tue May 08, 2012 1:31 pm
by tomsoffroad
If you need cert try Wayne Martin at Vehicle Certification Services.
Re: WOF Change?
Posted: Tue May 08, 2012 1:38 pm
by DDAN
Same place mate always flys through, that's what I said to him and his come back was you must of changed it since last time,VTNZ this is bull shit I'll have to pay 450 bucks for what nothing, if I had to pay for a cert for things like the front mount intercooler and methanol injection I wouldn't mined but for some thing that asnt changed since it was first imported from Japan what the
Re: WOF Change?
Posted: Tue May 08, 2012 1:42 pm
by tomsoffroad
Sorry to be a kill joy but................... technically these should be certed too. :wink: Apparently anything which increases power needs cert :cry:
Re: WOF Change?
Posted: Tue May 08, 2012 1:48 pm
by DDAN
Yeah thats the thing, this is what he as put down. Things that need to be certed Tires and spring lift, I said to him anything else no. And I haven't changed spring and tire combo since I've had it
Re: WOF Change?
Posted: Tue May 08, 2012 4:48 pm
by SV1K
Tyres don't need to be certified, it's the RIMS that need to be certified, there is a bit of difference there... but I would also tell them to get stuffed, the Nissan Safari/Patrol came out with 16 inch rims. You can lift up to 49mm before the can request a cert as 50mm is right on the edge according to my WOF man.
Reece
Re: WOF Change?
Posted: Tue May 08, 2012 4:56 pm
by 4WDbits
The WOF guy can say that in his opinion it needs a cert. Go see a cert guy and if he says it doesn't need a cert then the WOF guy has to accept his expert opinion.
Re: WOF Change?
Posted: Tue May 08, 2012 5:56 pm
by DDAN
Well this is getting interesting their is change coming to NZ laws, but this guy as jumped the gun by a few months
Re: WOF Change?
Posted: Tue May 08, 2012 6:54 pm
by 00falcon
DDAN wrote:Well this is getting interesting their is change coming to NZ laws, but this guy as jumped the gun by a few months
Whats the law change...?
im about to lift... :D
Re: WOF Change?
Posted: Tue May 08, 2012 7:02 pm
by sig
new rules are max 100mm including tires if you are member of 4wd association .if not max 50mm .If you are a member and your 4wd is 100mm lifted and you sell it to a non 4wd member you must lower it to no more than 50mm.If you are already certed for higher you are sweet as .So get your cert done soon as .I am trying to pull finger on my prado to get it done before the law change .
Re: WOF Change?
Posted: Tue May 08, 2012 7:22 pm
by tweake
4WDbits wrote:The WOF guy can say that in his opinion it needs a cert. Go see a cert guy and if he says it doesn't need a cert then the WOF guy has to accept his expert opinion.
i had the same with lowered suspension on a car.
it all came down to how the WOF person interprets the rules. fortunately only took a phone call to a cert guy to sort it.
Re: WOF Change?
Posted: Tue May 08, 2012 8:52 pm
by Mudde1
sig wrote:new rules are max 100mm including tires if you are member of 4wd association .if not max 50mm .If you are a member and your 4wd is 100mm lifted and you sell it to a non 4wd member you must lower it to no more than 50mm.If you are already certed for higher you are sweet as .So get your cert done soon as .I am trying to pull finger on my prado to get it done before the law change .
not quite correct.
Max of 100 mm increase in the distance between the center of the hub and the underside of the unmodified guard will be the maximum that a certifier will be able to certify, unless the vehicle has an authority card issued by NZFWDA.
Tony Burgess
President NZFWDA
Re: WOF Change?
Posted: Tue May 08, 2012 9:37 pm
by tallsam66
heard roumours & talk about this happening ...but nothing confirmed ...when does the proposed change go before parliament ?
Re: WOF Change?
Posted: Tue May 08, 2012 9:39 pm
by DA RAM
Mudde1 wrote:Max of 100 mm increase in the distance between the center of the hub and the underside of the unmodified guard will be the maximum that a certifier will be able to certify, unless the vehicle has an authority card issued by NZFWDA.
Tony Burgess
President NZFWDA
how will they work that out on a WB holden ute that was never a 4wd mine is lifted about 600 from stock :roll:
i dont fall into the 4wd or "club truck " as it never left factory as a 4wd so that rule will not apply to DA UTE 8)
Re: WOF Change?
Posted: Tue May 08, 2012 9:41 pm
by turoa
not quite correct.
Tony Burgess
President NZFWDA
How are they going to know what is a standard difference? No type of vehicle is going to be the same??
Re: WOF Change?
Posted: Tue May 08, 2012 9:47 pm
by evyauto
Just had mine certed under very similar reasons no change in 6 years to anything on the truck failed on suspension and wheels etc :( so i turboed it :twisted: and got a cert, i can understand the rule change and to save a lot of hassles in future i have to agree in certing mods. also any engine mod ie turbo, supercharge, transplant means you now have to put on drive shaft hoops on the rear shaft to
Re: WOF Change?
by Sadam_Husain
without getting back into all that bodylift arguement again its funny how the laws and certs and loopholes work I can bodylift the rear of my truck all I like but not the front :x :?
Re: WOF Change?
Posted: Tue May 08, 2012 9:48 pm
by tallsam66
So Tony what gives NZ4WD ass the right to see preferential rules for your members.This seems like a way to just fill your pockets with extra member ship dollars ...NZ4WD assn isnt the only recognised 4WD assn in NZ.
As NZ4WD assn is a share holder in LVVTA seems to be insider trading to me.
Re: WOF Change?
Posted: Tue May 08, 2012 9:50 pm
by evyauto
This topic could get rather interesting :?
Re: WOF Change?
Posted: Tue May 08, 2012 10:06 pm
by Sketchy_Racer
Tell the VTNZ WOF man he is a cockhole then take it to a workshop where the person doing the check isn't a failed mechanic with a ego problem. Nothing but trouble comes from VTNZ IMO
Re: WOF Change?
Posted: Tue May 08, 2012 10:17 pm
by Ralfie
tallsam66 wrote:So Tony what gives NZ4WD ass the right to see preferential rules for your members.This seems like a way to just fill your pockets with extra member ship dollars ...NZ4WD assn isnt the only recognised 4WD assn in NZ.
I thinks Tallsam has the 'tall poppy syndrome'
Re: WOF Change?
Posted: Tue May 08, 2012 10:34 pm
by Mudde1
A lot of work over a 20 year time frame by a lot of different members is what allows us offer authority cards to our members. no different to what Motor sport NZ offer to their members and NZ Hot rod offer to their members. While I do sympathize with members of other associations, this is done via a legal process we cant change, and no matter how much we want to, we cant offer to this to non members. NZFWDA is the only 4wd assn that has put in the effort and finance over a 20 year period to get to this stage.
i think it unlikely that we will profit from this, and if we did, it would go back to benefit all members.
Tony Burgess
President NZFWDA
Re: WOF Change?
Posted: Wed May 09, 2012 6:33 am
by tallsam66
gee intelligent comment there
Re: WOF Change?
Posted: Wed May 09, 2012 6:49 am
by tallsam66
So to have an authority card it will cost you your 4wd ass fee annual fee ($25) plus the application fee ($40) plus the annual renewall fee ($25) ..seems like alot of money is going to be made here.
Tony Burgess
President NZFWDA
Re: WOF Change?
Posted: Wed May 09, 2012 6:54 am
by wjw
tallsam66 wrote:So to have an authority card it will cost you your 4wd ass fee annual fee ($25) plus the application fee ($40) plus the annual renewall fee ($25) ..seems like alot of money is going to be made here.
not really, you price up the insurance that the 4wd Association has and you'll see why they charge what they do.
