Extended Shackles
Extended Shackles
Feroza F300 extended shackles anyone know a place that sells/makes them big enough to give a 2inch lift???!
- Moriarty
Re: Extended Shackles
FerozaMad wrote:Feroza F300 extended shackles anyone know a place that sells/makes them big enough to give a 2inch lift???!
(Bracing myself for a flaming)
Make 2 inch higher mount points, use the original shackles, because to just make longer shackles leads you to doing wrong things to the geometry and stresses of your springs
you'd be lucky to get 2" of lift out of the front end, and if you did you would have pretty much no travel, as the torsion bars would be wound up that tight better idea is to get the leaves reset and a bit more arch put in them. i had about 40mm done in mine and wound the front end up about 30mm to match i was running 31's and wouldnt want to go any bigger as they sucked the power pretty badly
cameronmaxwell@xtra.co.nz
0274202727
0274202727
