engine stalling
For all Suzuki related topics
mushroom11
engine stalling
Post by mushroom11 »
i have a sj413 now 4 some strange reason arfter climbing steep hills the engine stops idleing and will stall it only happens when climbing steep hills on a closer investigation i noticed that the pipe comeing from motor to air filter box had water looking oil in it comeing from that pipe????any advice on whas happning an advice will b good?
Madaz
Post by Madaz »
Hi there
Try checking your fuel filter , if you truck has shit in the fuel tank all the bouncing around off road can move it off the bottom of the tank in to the pickup and it just overloads the filter giving you a short period of fuel starvation,I've had it happen in my samurai and know what a pain it can be.
mushroom11
it has a new filter but will check but as i said it only happens on steep hills
Clint
Post by Clint »
Keeping your tank full helps.
Clint
UZJ71 Landcruiser
KTM 640
mushroom11
yea i keep the tank full checked fuel filter its ok just doesnt want to idle :?: :?:
Smurf
Post by Smurf »
you may find that on steep angles oil is running to your airbox and then clogging your carb. We used to have Suzukis with datsun motors in them that did this , they kept running but blew a heap of black from the oil. We fitted a catch container before the airbox and occasionally drained the oil from it back into the sump.
mushroom11
definately had white creamy oil in air box but no obvious signs of oil in carb done 60km since it happend but still wont idle.
Ben
Post by Ben »
If its not idling you've probably got crap in your idle jets.
As suggested probably came from crap in the tank getting shaken up, or crap in the float bowl.
Open up your carb and have a look if there is any dirt in there. Mine used to block up all the time when I had a carb on it.
Best solution to fix it if there is dirt in there is to take the tank out and clean it right out, blow out the fuel lines, clean the carb, and make sure your fuel tank breather is up nice and high and not sucking mud in.
Quick way to fix is to do a "Mexican tune up". Take off carb hat, rev motor lots and stick hand over top of carb till motor slows and almost dies and repeat.
Just be carefull as it will suck pretty hard so don't block it totally.
The sludge in the PCV line will just be a bit of blow-by and condensation, so I wouldn't worry about it unless its really bad.
I assume you've checked under the oil cap to make sure theres no white stuff in there from a blown head gasket?
Ben
mushroom11
k mate its a reconditioned carb on it wouldnt there be evidents of dirt and junk in fuel filter if that was the case?any way picked up another carburator offa suzuki swift 1.3 for 26 bux so mite completley swap it
Madaz
Post by Madaz »
Hi there,I would also check your fuel tank breather that comes out by the number plate to make sure its not half full of crap.If its stalling going down steep hills as well I would have a real good look at you idle jets for any kind of contamination.It takes next to nothing to make them play up.
If the problems only occuring off angle I'd be having a pretty good look at the float levels and stuff in the carb to start with?
mushroom11
mate will do that is gord dam annoying alright!!!!!!!!
Pinch one of your mates carbs for an afternoon and see if it makes any difference?
Ben
Post by Ben »
It only takes a tiny bit of dirt to block the idle jets, and sometimes you wont even see anything in the float bowl. Just about every Suzuki I've seen has had trouble with blocked jets at some stage.
I'd just do a quick "mexican" tune up and see if that helps. It will only take a couple of min and shoud suck any crap through the jets it there is anything in there. You may have to repeat a few times and give it heaps, but it works really well.
If its still bung, then go ahead and swap the carb.
If its stalling all the time its probably the idle jet. If it only stalls on hills its probably the floats.
If you do have lots of white crap under the oil cap and in the PCV pipe it could be a blown head gasket which can also make it idle rough.
Also beware that the swift carb probably has a different float bowl to a 413 carb that doesn't like side angles or up/down and makes it run out of fuel in these situations.
Ben
Rangielux
Post by Rangielux »
If it's not idling at all. Has it got a fuel cut solinoid on the carb? - one single wire going to a small round soliniod near the top of the carb?
If so make sure that is working correctly. Clicking and the pintle going in and out etc.
mushroom11
thanks guys fixd problem i think :?: :?: :?: :?: done the mexican thing then came right will soon se how it goes when comes to the hills again.but will clean carb on the weekend aswell.
Return to “Suzuki”
