mq diff head into gq
Posted: Sat May 19, 2012 7:34 pm
by PigFmr
right have found a complete mq running,
i know the crownwheel and pinion will fit into my saf.
are the diff housing the same ?? ,hoping they will just swap ovr and all i have to do is swap both my lsd's out into mq diffs
any help would be great
thanks vince
Re: mq diff head into gq
Posted: Sat May 19, 2012 7:55 pm
by taz01
front gq same as rear mk/mq only
Posted: Wed May 23, 2012 11:54 pm
by charo249
Housings are different MQ/MK have a H233 rear diff (meaning a a banjo style with a 233mm crown wheel) and a C200 front (200mm crown wheel and a salisbury style housing with removeable faceplate). GQ have H233 diff front and back, they are also wider and the pumkin is in the centre at the back rather than offset to the drivers side as on the MQ. However if you need MQ/MK parts let me know as I have a mostly complete parts truck.
Posted: Mon May 28, 2012 8:10 am
by PigFmr
the front and rear crownwheel and pinoin will still fit in my GQ thou ??
Posted: Sun Jun 03, 2012 9:07 pm
by charo249
You can only use the back crown wheel - the front crown wheel is smaller which will most likely mean that it won't mesh with the pinnon properly in the housing
