diffs
foxman12130
Newbie
Newbie
diffs
Post by foxman12130 »
Hi folkd got a terrano 11 2.7 td auto 1995 mistral putting in a manual box from a 1996 2.7 td are the diff ratios the same or do I need to swap axles aswell. cheers
slide
Re: diffs
Post by slide »
Hava look at chassis tag, you probably got hg43 ? means 4.3 ratio diffs. Terranos mostly 4.6. Not a huge difference, specailly if you running smaller tyres. Get the box changed and see how it suits you, then do later if it doesn't feel right. Keep us posted how you get on with the conversion :D
