60 series PTO winch
jex_the_bug
- Bush Crasher
60 series PTO winch
pto winch and bumper from my old 60 series. very strong winch, worked well but have two and need to clean out the shed. has wire rope and think the input shaft from the gearbox is all there to.
$400.
pickup queenstown.
$400.
pickup queenstown.
Re: 60 series PTO winch
Hey mate,
What year 60 series is this from??
Is it a complete kit?? If not what else is needed to make it complete.
Marc
Marc
- mudlva
Shark wrote:Hey mate,
Marc
dont matter on the year as they will all fit
- mudlva
oh yeah check the trans box to make sure its got the pto drive sprocket installed as some imports came out with out the pto sprocket
Mine is a 85 5 speed, just trying to work out if it will fit..
Im led to believe the PTO drive box is different between the years.
Shark wrote:Mine is a 85 5 speed, just trying to work out if it will fit..
Shark wrote:Hey there, new to the site.
Was lurking around the net looking for a PTO for my 4wd and came across this site and thought i would join up![]()
I drive a 1985 Nissan patrol cab chassis. Its had quite a bit of work done, running a garrett 2860, FMIC, twin ARB air lockers, Bf goodrich KM2 (35's),
3" mandrel bent exhaust and heaps of other goodies all built by me:)
would I be right in thinking you've got a Nissan and not a 60 series landcruiser?
Facepalm... dammit..
Thought 60 series patrol
Shark wrote:Facepalm... dammit..
MK/MQ pto winches are slightly different to GQ's, the top pic is a wider MK/MQ winch and the bottom pic is a GQ, you can make them fit by shifting the mounts around a bit, dunno if the PTO shafts and PTO drives are the same or not?
- crazyclark31
off topic i know but
The landcruiser winch fits on safaris pretty easily. had one on my last safari. just need the output box for the side of the gearbox and the lever kit
where abouts are you based?
jex_the_bug
- Bush Crasher
still have it,
got some photos too.
jex_the_bug
- Bush Crasher
still have it
- IcedJohnno
- Trailer Trash
Do you have the output box that bolts to the transfer case? The drive shaft goes into it.
jex_the_bug
- Bush Crasher
no sorry, not the bit thats part of the gear box
