Hi guys,having issues with my 93 terrano diesel.Jumped in it today,started as per normal,drove 4 blocks and engine cut out while driving.Now it turns over but wont start.Wasnt making any noises or blowing smoke etc.Oil still black-water still clear.
Anyone have any ideas where to start looking????
Diesel pump has been leaking,but it still been running fine.
W.T.F?
terrano wont start
- rangimotors
Re: terrano wont start
yip pump is probably shagged
is there fuel to the hand primer on top of the filter ? if so crack one of the injector pipes off and crank it over there should be diesel squirting out , if not there is an issue with either the pump or wiring (fuel cut off solenoid) etc
Hi guys,thanks for the replies.Mechanic mate had a look(truck conked out near his house-sweet).Says it keeps blowing a fuse.Bum still sore from last trip to auto sparkie so hopefully I can find a bare wire,bad connection etc.Cheers
Was the fuel cut solenoid,cheers
