failed cert - after your opinions
- jonossiksilvia
so took my truck for cert today and failed on 2 things:
need a sway bar on the front
brakes not good enough
the truck (1990 surf) has a coil sas swap from a prado fitted. will a prado sway bar fit? anyone have pics of one fitted to a surf or prado esp pics of where it mounts to the chassis?
brakes: failed on brake fade on third stop and lots of pedel travel. - hits floor and 35's fitted to truck.
has rebuilt 4 pot calipers
new rear cylinders for drums
4wd bendix pads
machined rotors
total $600 bucks from save r brakes
full fluid change
i bleed the brakes 5 times
is it time to get the master cyliner rebuilt? is it cheaper to rebuild or buy new?
what else could be the problem?
is it possible to pass cert running 35"s?
searching didnt help
4wd bendix pads
machined rotors
full fluid change
Re: failed cert - after your opinions
did you set the load sensing valve to match the suspension lift?
all i did with mine was make a bracket to lift the mount on the diff to the same height as the lift.
master cylinder about 170 bucks from repco, worth replacing if you have excess travel, apparently the spring inside goes weak over time reducing rear brake pressure? you can get kits from repco/bnt but i dont think its worth all the arsing about. i just bought a new one earlier this week.
weemsy
weemsy
- Spring Free
hey i dont have a surf but iv got a coiled zuk with after market sway bar set up if you want to come and get ideas etc over the weekend flick me a txt 0273012035 Rich
Does your rear proportioning valve have a bleed nipple on it ? if so try bleeding it up there they can get air bubbles trapped up there.
Also see if you can get a master with a larger bore on the cylinder, the pedal will then be required to travel less to push the same amount of fluid.
sintered metal pads in the front will pullit down quick too they like heat
- KIWI_TERRANO
Whats your number? I had same issues could give u a txt or a bell
if you've got lots of pedal travel and the pedal hits the floor when braking the jokers right you've got brake problems. Could be the M/C or it could be lack of adjustment on the rear drums, easy way to see if its the rear drums causing the problem is to clamp off the rear brake hose with a pair of vice grips and see if the pedal comes back up hard and dosent hit the floor. Its all time and money which no one seems to have these days but a good oppotunity to ditch the stoopid rear drums and throw a set of discs on the back and if you've got another $400-500 bucks to spend on a second VH40 remote booster to stick on the front brake circuit you'll be peeling your face off the windscreen everytime you hit the brakes too hard with 35's on
- jonossiksilvia
Weemsy wrote:did you set the load sensing valve to match the suspension lift?
weemsy
i think end of day ill get a new master cylinder as its prob the orginal 1 (282xxx,kms). load sensing valve was adjusted and the cert man said he can notice the rear brakes working
- mud_slinger
i reckon jono pop down and see rick, he may have a idea what swaybar you could use and how to mount it and even give ya the right advise on brakes
needs more curry
0272593533
0272593533
- jonossiksilvia
muddyplumber wrote:hey i dont have a surf but iv got a coiled zuk with after market sway bar set up if you want to come and get ideas etc over the weekend flick me a txt 0273012035 Rich
thanks will be in touch if i have no joy from anyone running same setup as me first - i dont like wasting peoples time if ya now wat i mean
- jonossiksilvia
nztimr33 wrote:Does your rear proportioning valve have a bleed nipple on it ? if so try bleeding it up there they can get air bubbles trapped up there.
no nipple but did crack the fittings the same way you do with the m/c
- jonossiksilvia
Crash bandicoot wrote:Also see if you can get a master with a larger bore on the cylinder, the pedal will then be required to travel less to push the same amount of fluid.
maybe a goer.
coxsy - got a link mate?
kiwi - have gone through your build thread and a few others - will be in touch
- jonossiksilvia
Sadam_Husain wrote:if you've got lots of pedal travel and the pedal hits the floor when braking the jokers right you've got brake problems. Could be the M/C or it could be lack of adjustment on the rear drums, easy way to see if its the rear drums causing the problem is to clamp off the rear brake hose with a pair of vice grips and see if the pedal comes back up hard and dosent hit the floor. Its all time and money which no one seems to have these days but a good oppotunity to ditch the stoopid rear drums and throw a set of discs on the back and if you've got another $400-500 bucks to spend on a second VH40 remote booster to stick on the front brake circuit you'll be peeling your face off the windscreen everytime you hit the brakes too hard with 35's on
ive pretty much decided a new m/c is the go. the cert guy did say he could tell the rears were working fine. rear disks are option but not at this stage unless necessary needed. yeah remote booster does spring to mind but have a very cramped bay as it is. cheers
- jonossiksilvia
mud_slinger wrote:i reckon jono pop down and see rick, he may have a idea what swaybar you could use and how to mount it and even give ya the right advise on brakes
cheers hamish will give him a ring after weekend
my garage got some for my safari , any lining shop could do them for ya
- jonossiksilvia
ln130 surf have 2 different bore sizes for master cylinder
i think it 23.8 mm & 25.4mm i got the larger one for my truck
the part number on the box is 47201-3d070
I have the front sway bar in pieces from my prado, I can take pics showing the mounts etc and it sitting roughly in place if you want. It will have to be after the weekend though as I am away tomorrow for the long weekend.
- jonossiksilvia
Weemsy wrote:ln130 surf have 2 different bore sizes for master cylinder
yeah just found that out on google as a previous said get a bigger bore
cheers for p/n
- jonossiksilvia
Smurf wrote:I have the front sway bar in pieces from my prado, I can take pics showing the mounts etc and it sitting roughly in place if you want. It will have to be after the weekend though as I am away tomorrow for the long weekend.
that would be awesome mate cheers
You shouldn't need a remote booster on a surf, mine has passed two certs on 35s, still drums on the rear. Did you bed them in properly when you bought the pads, could be something as simple as that?
- jonossiksilvia
gimmemud wrote:You shouldn't need a remote booster on a surf, mine has passed two certs on 35s, still drums on the rear. Did you bed them in properly when you bought the pads, could be something as simple as that?
yeah bed in the way brake place advised. kiwi just rang me and yeah he didnt have extra booster and was running drums with 35's and he passed
Id get it on a set of brake rollers and see whats going on before replacing bits
think there is a vh 40 booster at work will have a look if I get a chance
Warren
Warren
- jonossiksilvia
Maxfab wrote:Id get it on a set of brake rollers and see whats going on before replacing bits
might be an idea but it does brake straight and cert man said he could tell the rears were working. will get at least the pedal feeling better before i even thick of a roller test
- jonossiksilvia
aroma wrote:think there is a vh 40 booster at work will have a look if I get a chance
Warren
that be great but the 1uz is like a "package" in a g-string
- tomsoffroad
- Flopsie
If your peddle is going to the floor I'd say youve still got air in the system. The proportsioning (spelling
) should have a bleed nipple facing the rear bumper, yet to see one which doesnt. I've had troubles with the brakes on that red double cab. Put disks on the rear and ended up having to pressure bleed the system. Brakes are alot better now but are looking at finding a bigger booster.
As for your sway bar when Sam (Jammysammy) got one made for his Surf he bent up a mock up swaybar out of 20mm rod, then took that to Ballemy & East and they copied it. Think it cost him $150.
Only two issues tho, you must have sone a pretty good job there fella
Does the pedal always go to the floor or just after he's done the brake test an boiled the brake fluid in your calipers? Does the pedal feel ok when you've bled it an adjusted the shoes?
Didn't barbie drive a jeep??
Just a thought.
How old are your brake hoses?
May be worth checking them all for splits or bubbles when the brake peddel is pushed by a helper.
