3.0lt Hilux Turbo conversion In or near Tauranga ??
Re: 3.0lt Hilux Turbo conversion drive in drive out ??????
Helps if you put what part of NZ your from mate! put it in your profile.
Re: 3.0lt Hilux Turbo conversion In or near Tauranga ??
DTech Motorsport are pretty on to it by all accounts.
- KIWI_TERRANO
Arb dealer can get the safari turbo kits in to
Tauranga Diesel is the ARB dealer and do a lot of that sort of thing, bit pricey tho
two ways of doing it.
cheap way is to use turbo and manifolds off 2lte 2.4 surf motor.
or use one of kits ie safari, dts etc. a lot more expensive as your buying a new turbo and manifold but the good kits have everything included.
only hard thing is fitting turbo oil drain.
