help identifyingrover v8 blocks
Posted: Tue Jun 05, 2012 10:16 pm
by davey32
hi everyone would anyone be able to help identify the numbers on the rover v8 blocks CR8.13.1
10G09780
and the heads have ERC0216
Y.5E652
and the other one has 9.25.1CR
48111392D
thanks for your help
Re: help identifyingrover v8 blocks
Posted: Tue Jun 05, 2012 10:34 pm
by NJV6
Try googling rover v8 engine numbers, there are heaps of web sites with them on, that's how I found mine.
Posted: Tue Jun 05, 2012 11:14 pm
by L-andy
Don't know about the other numbers but the cr is compression ratio. 8.13:1 was low compression version usually fitted to military rovers designed to run on low grade fuel. 9.25:1 is the civvy spec fitted to early range rovers etc. I'm led to believe that it's the pistons that determine the cr and not the block but don't quote me!
Posted: Wed Jun 06, 2012 5:24 am
by ice4x4
What exactly is it you need to know?
1st one looks like its out of a stage 1 V8 Land Rover from 1982 with 8.13:1 compression ration.
2nd one is an oldie out of a P6 3500S manual car from around 1967-1976 with 10.5:1 compression ratio.
Posted: Wed Jun 06, 2012 5:47 pm
by davey32
orsm thanks guys thats a good help
