changing coils/ shocks in 92 prado
am getting a spring lift kit tomorow for my prado. can someone in chch show/change them over for me. u be paid in southern money.. the sort with 3 stars
When doing a suspension lift, how high could you go before you would need a wheel alignment? if at all. Am about to tackle Mudbums SWB Safari and fit 60mm lift springs and long travel shocks. If this goes according to plan i'd be keen to help you Kaney. Have you got longer travel shocks as well?
Can't be that much difference between a nissan and a toyota
(how long before this is quoted back to me
if it's got TITS or WHEELS it will cost you MONEY.
Aint that the truth
When you lift up a safari it changes the castor on the front 60mm is probably going to be ok, much higher and you need offset bushes in the arms to change the angle of the diff to correct the castor angle
Have you got a good coil spring compressor?
Toyota 70 series cruiser, 13bt
Phone 029 454 8533
Phone 029 454 8533
G'day, I'm shopping for new springs & shocks for my prado at present so I'd be keen to hear what sort of stuff you got & how it goes once it's in there.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Clint wrote:G'day, I'm shopping for new springs & shocks for my prado at present so I'd be keen to hear what sort of stuff you got & how it goes once it's in there.
Clint
Cobra springs & Monroe Shocks (Chamberlains Christchurch) have heard this setup is too hard. Although after more research (DieselBoy) it may just be the shocks. Lots of Prados down here have this setup though, so it's well used/documented.
Front coil springs
Chamberlains part number – CTFR-116 SP
130 mm OD
15mm wire diameter
10 turns in coil
480mm open length
Pounds rating on coil same as factory 13mm coils
This gives approx 110mm free travel to bump stop
Rear coil springs
Chamberlains part number – CTRR-240 SP
150mm OD
17mm wire diameter
10 turns in coil
490mm open length
This gives approx 180mm free travel to bump stop
Front shocks
Monroe Gas Magnum 16-0188
U shape bracket to be made for the top shock bracket – see drawing
Brake hose from diff to chassis to be lengthened.
Rear shocks
Monroe Gas Magnum 16-0189
25mm spacer needed for bump stop, LH side only.
EFS & ToughDog - Genie4x4
We do Toughdog & EFS Suspension only. Rancho will not warranty their 9000's
for medium to hard offroad use. Toughdog has similar and heavy duty
adjustable shocks available with in cab control as well. Toughdog is
designed for serious offroading, while EFS is a more tuned suspension for
all round manners. EFS shocks range from $90-$150 each, Coils around $160
each.
Toughdog springs are around $125 each so its not much to replace them if a
winch is fitted.
Toughdog shocks range from Gas $145, Foam Cell 41mm $185 & Tough Dog 35mm 9
way adjustables $225, Toughdog HD 45mm 9 way adjustables and Ralph heavy
Duty 52mm $320 each.
9 way adjustables have the same valving and components for adjusting as
Rancho, they also can use a rancho in cab controller or you can fit the
electronic toughdog one (I use this).
Steve aka SupraLux could source Rancho 9000's which I what I started off wanting and still would like. Was planning on Rancho shocks with Chamberlains (Cobra) springs. I have the in Rancho in-cab controller already, the toughdog 9 stage will work with it so may go that route. I have heard the warranty on Rancho's isn't as good as Toughdog
Toughdog Suspension
http://www.toughdog.com.au/
EFS Suspension
http://www.efs4wd.com.au/frameset.html? ... n.html~efs[/b]
Who knew Prados could fly?
wjw wrote:EFS & ToughDog - Genie4x4We do Toughdog & EFS Suspension only. Rancho will not warranty their 9000's
Interesting comment from Craig... I have not had a Rancho fail without significant abuse (as in, huge rock in the side of the body, incorrect bump-stop settings, etc), and I would be very surprised if I had trouble with the warranty on them (probably helped by the number of them I have moved). OH, and the pricing of the Tough Dog shocks is way out there... the Ranchos are about 30% cheaper per pair!
The one thing I would have to disagree with is the Rancho application Craig from Genie came up with - "not for medium to hard offroad use" ???!!! Thats exactly what they are for.
The Chamberlains coil springs are recognised as being harder than some aftermarket ones... but without importing custom Dobi ones from Oz who else does 4" off the shelf?
Steve
H2OLOVA wrote: If this goes according to plan i'd be keen to help you Kaney.)
i may have to take you up on that offer. i have to the complete set up out of this truck
http://www.trademe.co.nz/Browse/Listing ... d=64504498
efs shocks in the front, chamberlands springs and the stickers are no longer on the rear ones
