I stopped the project because of different interpretations of what you were allowed to
I'm sick of it sitting there taking up space so decided to get it done, after talking with a few people I respect (not you bob if your trying to get out of that bottle you owe me
This originally started as a Lada Niva I traded for some hilux bits
The original idea was to turn it into an A class trials truck and I started down this path but couldn't find any way to strengthen the axles so decided to change to E class
The final call is hilux axles front and rear, SR20de motor and front wheel drive auto, with three link coilover front suspension
Since this is going to take alot of typing to put up all the stuff I've done it can go up in stages
Rear Axle
LN130 rear axle..... cut all the suspension mounts off the original Lada axle and welded them on...
One small problem, increasing the diff size from 6.5" to 8" caused a slight problem with the Pan hard bar
So
remade the axle mount
up top a little trim and bend
and the standard lada pan hard fits
