3 inch exaust systems. where to buy. 80 serries and safari
Posted: Tue Jun 19, 2012 4:59 pm
by pruggerdore
ok so 80 series exaust is sad so figure upgrade to 3 inch as word on here makes a big difference. so where are people buying system from? brand? experiences and opinions please
and since where on the topic same for safari too? lwb
thanks Clive
Re: 3 inch exaust systems. where to buy. 80 serries and safa
Posted: Tue Jun 19, 2012 5:01 pm
by Jerry
autobend sell them off the shelf, 4wd bits sells them as well, pays to shop around as your local exhaust place may be able to do it cheaper, you want to look at a bigger turbo dump pipe as well
Posted: Wed Jun 20, 2012 6:47 am
by wjw
Posted: Wed Jun 20, 2012 8:08 am
by wopass
Posted: Wed Jun 20, 2012 7:09 pm
by 80series
I've just had my 80 series done with a mandrel bent 3" on Monday. It was substantially cheaper than the auto bend ones, which I've heard can be a bit of a mission to fit.
My advice would be to go visit a few exhaust outfits. I had quotes from $900-$1400.
Dave
Posted: Wed Jun 20, 2012 7:59 pm
by skid
80series wrote:I've just had my 80 series done with a mandrel bent 3" on Monday. It was substantially cheaper than the auto bend ones, which I've heard can be a bit of a mission to fit.
Dave
Jerry wrote:autobend sell them off the shelf, 4wd bits sells them as well, pays to shop around as your local exhaust place may be able to do it cheaper, you want to look at a bigger turbo dump pipe as well
Holy crap
I went to my local muffler shop recently for a quote to get my side exit pipe replaced from the turbo back, which would use 1 flexi joint, 1 19" coby and about 3m of 3" pipe
I was horrified to get a quote for $600 :shock: :shock:
It made the bolt on 3" off the shelf exhausts look bloody cheap to me
Posted: Wed Jun 20, 2012 8:16 pm
by turoa
Dave
Holy crap
Jeebus!! Id fly up and do it myself for $500
Posted: Wed Jun 20, 2012 8:29 pm
by skid
and I don't even think I need the muffler
would rather a straight thru pipe anyways
Posted: Fri Jun 22, 2012 10:33 am
by Andrew1706
May as well chuck this question in here..
Anyone with 80s done an 'inside the chassis rail' 3" exhaust?
I started making a flange for the turbo outlet to make a straight downpipe instead of that stupid point at the wheel cast elbow thing.
Posted: Fri Jun 22, 2012 7:23 pm
by zephyrheaven
Replaced mine with an Autobend / Rage 3" - fit was OK, tip hits the rear bumper so had to trim it. Thats replacing dump pipe too, no bloody flexi in it worries me however
Should have gone to Mr Muffler Opawa like everyone else in Chch - he is cheap as chips, hand made 3" to suit a 1KZ in a D/C Lux for a mate - sounds insane, cost was half of my 'pre-made' system
Bugger
Posted: Sat Jun 23, 2012 7:53 pm
by wjw
zephyrheaven wrote:Replaced mine with an Autobend / Rage 3" - fit was OK, tip hits the rear bumper so had to trim it. Thats replacing dump pipe too, no bloody flexi in it worries me however
Bugger
I got a rage 3" for the cruiser it has a flexi in it
Posted: Tue Jun 26, 2012 7:40 pm
by zephyrheaven
Bugger
Sorry, quite correct - but thought mine should have been closer to the front pipe?
Posted: Tue Jun 26, 2012 8:48 pm
by pressy
I had a 3" bent up and fitted with a flexy and only cost $800 from Lee at Hornby exhaust , had a quote from Rangiora exhaust and he want $1500 to get a pre built one and fit it :lol: :lol: :lol: guess what i went with 8)
Posted: Wed Jun 27, 2012 12:21 pm
by Danjr
Autobend do a bare pipes only kit for the 80 series for around $400 which is the way I went. It doesn't include muffler, flexi or flanges and is unpainted. I grabbed some flanges (only needed 4 plus the dump pipe one) and a flexi and gave the muffler a miss which meant I needed a little bit of extra 3 inch pipe to fill the gap. Got a mate to weld it up after work one night. Cost me about $700 all done. It still flies through warrant's without the muffler as the turbo keeps it quiet enough.
If I didn't have the mate to do the welding I would have gone with the one from 4wdbits as the local guys couldn't give me an estimate and would only say it depends how long it takes.
Posted: Mon Jul 16, 2012 3:27 pm
by strx7
I can supply those Rage 3 inch systems for $1150 inc courier if anyone wants one.
they are a good systems and are a piece of piss to fit. usually takes about 4 hours total, 2 1/2 hours to remove the old system and 90 mins to bolt the new one into place.
not sure why people want to replace the turbo dump pipe on a 80 series, the one on mine was approx 70mm diameter from factory.
