Parts supplier WD21 Balljoints, TREs etc
For all Nissan related topics
lax2wlg
Post by lax2wlg »
Hi there
Wheres the best place to get suspension balljoints and steering tie rods for these trucks? I'm in Wellington but would also order online if price was better.
Also, looking for the cup-washers for the tension arms (compression rod) bushings - I have new bushings and sleeves, but need washers
Also looking for the clutch slave cylinder boot where it bolts to the trans bellhousing
Anybody have any ideas??
sibainmud
Re: Parts supplier WD21 Balljoints, TREs etc
Post by sibainmud »
Ball joints and TRE's from BNT, but TRE's they are cheap crap that only last a few weeks before getting flogged out :roll:
Washers from any wrecker that has a D21.
Slave cylinder boot.....who needs it, they do f*** all.
You can get complete new cylinder for real cheap from BNT as well :wink:
lax2wlg
Post by lax2wlg »
Cheers, yeah I guess 33s and torsion twist will spit the TREs pretty quick. Is there a supplier of moog tie rods in NZ??
marrco
Post by marrco »
lax2wlg wrote:looking for the cup-washers for the tension arms (compression rod) bushings - I have new bushings and sleeves, but need washers
Autolign have them... here is the part number http://www.nolathane.com.au/product_detail.php?part_number=42933
DEATH_INC
Post by DEATH_INC »
sibainmud wrote:Ball joints and TRE's from BNT, but TRE's they are cheap crap that only last a few weeks before getting flogged out :roll:
From Bnt (and/or Autolign; same company :wink: ) ask for the 555 brand stuff, it is made in japan and very good quality.
I also believe they are going to have the moog (federal mogul) brand shortly-ish.
kiwipete
Post by kiwipete »
DEATH_INC wrote:I also believe they are going to have the moog (federal mogul) brand shortly-ish.
Let us all know if you hear more about this please. I was looking at getting some from the US but the freight is a killer there.
Ph 0212078472
slide
Post by slide »
lax2wlg wrote:Also looking for the clutch slave cylinder boot where it bolts to the trans bellhousing
Do you mean rubber boot on clutch cylinder, or rubber boot on clutch fork to stop water etc getting inside bellhousing?
Cochram nissan do some good prices (and some not so good :lol: ). Check their listings on trademe and ask for a price if they don't have what you after.
