Intercooler options
RJT
Intercooler options
Post by RJT »
I'm wondering if anybody has used a standard GTI-R Pulsar top mount intercooler on a Terrano before?
I know the popular choice is to use a Bighorn intercooler but they seem to be few and far between at the moment, but have found a GTI-R one I could get for cheap, just haven't heard of people using them on Terrano's.
Unless somebody in ORE world have a spare Bighorn intercooler I could buy off them? :lol:
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
sibainmud
Re: Intercooler options
Post by sibainmud »
Closest I have got is using a GTi steering wheel :lol:
Bighorn bonnet scoop, Mistral intercooler :wink:
Far less shagging around.
likemagic
Post by likemagic »
Maurice
KZN185, 1KZTE running needing birthday
mud_slinger
Post by mud_slinger »
can ask my wrecker if he has intercooler kits lying round last time i was there he had 6 or so kits lined up
good price too
needs more curry
0272593533
crazyclark31
Post by crazyclark31 »
it would work using the gtir cooler and would work well. just not a sraight fit.
fullthrottle
Shuttle Queen
Post by fullthrottle »
likemagic wrote:check this out before using a car intercooler http://autospeed.co.nz/cms/title_Diesel-Intercooling/A_112608/article.html
Very interesting read. cheers
KIWI_TERRANO
Post by KIWI_TERRANO »
Guy out at rangiora sells bighorn parts, horsebut on trademe about 60 a intercooler and 80 a scoop from memory
RJT
Post by RJT »
Cheers for the answers all...
sibainmud wrote:Closest I have got is using a GTi steering wheel
:lol:
mud_slinger wrote:can ask my wrecker if he has intercooler kits lying round last time i was there he had 6 or so kits lined up
good price too
What kind of kit we talking? Top mount to suit 4x4s etc?
mud_slinger
they are bighorn cooler kits come with intercooler,scoop,rubber that hangs under bonnet and a couple of turbo pipes
needs more curry
0272593533
passengerpete
Post by passengerpete »
i used a rx7 one on my old d21 navara once.
RJT
Post by RJT »
mud_slinger wrote:they are bighorn cooler kits come with intercooler,scoop,rubber that hangs under bonnet and a couple of turbo pipes
Sweet! It'd be choice if you could find out. Cheers.
sibainmud
Post by sibainmud »
One major criteria need.....a 2 inch body lift to make the squeeze easier :wink:
I have said my bit above.
I'm not a fan of bends in boost pipes as they can be resistance not to mention lag.
RJT
Post by RJT »
sibainmud wrote:One major criteria need.....a 2 inch body lift to make the squeeze easier :wink:
I've got one of those... Though it is still sitting on the back seat waiting to go in :?
Definately a nice install that! Might look into the Mistral cooler. No doubt they're like rocking horse $hit.
sibainmud
Post by sibainmud »
Not that rare. Took a day of searching to find. Not the cheapest cooler around, but when you factor in the cost of the extra components required it works out quite cheap :)
I won't go into how much you value your own time.
Worth doing a search around your way. Intercooled Mistrals are from 96 up (the ones with the round headlights).
RJT
Post by RJT »
Will defiantely have a ring around the wreckers and see what I can dig up. Thanks for the advice! WIll report back if/when I find something suitable :twisted:
travis2ninja
Post by travis2ninja »
sibainmud wrote:Image
Those two pipes painted blue.
Are they off the Nissan Mistral/R20 Terrano II.
Or did you make them?
keithal
Post by keithal »
travis2ninja wrote:Those two pipes painted blue.
they are silicone bends
you may be able to get them at repco/supercheap etc
travis2ninja
No, those two pipes that are bolted to the Intake manifold and Turbo.
Also that pipe that runs from the crossover pipe, down to the injector pump for the boost compensator. When i put the intercooler on. Where do i attach it to? Because there is no pipe fitting on the intercooler itself. Do i make it longer and tee into where the waste gate actuator is, or drill and tap like you have done?
sibainmud
Post by sibainmud »
Made the pipes. Drill and tap somewhere easy to get to and that is where the boost compensator and aftermarket gauge are plumbed in.
Here's a pic showing the mock up.
travis2ninja
Thanks,
You wouldn't happen to know what kind of pipes are on the Nissan Mistral?
Or is is a different manifold and turbo housing?
sibainmud
Post by sibainmud »
The two hoses that you see are the standard ones off the mistral. They do have different manifolds and the later model garret turbo. I did mine this way apart from my tubes , everything else is standard factory. Makes for easy replacements as I seem to need from time to time :twisted:
danielbeek
Post by danielbeek »
Hey Simon, don't suppose you could tell me the dimensions of that Mistal intercooler core (excluding 'end caps')? Interested to see how it compares with my yet unfitted Bighorn cooler.
Cheers.
sibainmud
Post by sibainmud »
Intercooler is currently in the back of my truck up north, so it won't be until after the weekend.
Stand by.
travis2ninja
Mine is off a Nissan Mistral/Terrano II...
It measures at 245mm x 240mm x 70mm
slidenyo
Post by slidenyo »
i'm interested in the logic behind these top mounts after reading that article and the importance in the execution.
if your trucks up to its balls in mud, the heat will rise,
energy always looks for the easiest path to dissipate so its likely going to head for your intercooler vent hole in the bonnet,
by the by it will heat the bejesus out of the intercooler unless you're underway and your truck isn't up to its balls which would then mean the heat will be pushed down and out by the air flowing in through the radiator and grill.
so possibly a heat shield below the core and some careful consideration to which way your cooling fan runs (and where it draws air from)will be needed to maximise the efficiency of your cooler.
buddrick
Post by buddrick »
I have a water to air and I will never go back it does depend on what u do and when you do it!! They all have there good and bad points!!!!! If you want to wind up yoour boost and fule and not want to melt a piston then intercooler is there way!!! If u drive at speed and put ur hand out there window then yes lots of air but when bush and only just moving but your speedo is cranking then no air flow a pwr intercooler there only way!!!!! Even when ur sick of those gay boy racers at there lights my intercooler is rady to go
Q
slidenyo
Post by slidenyo »
pwr are nice but jeez the coin involved sucks,
Subaru water to air work well.
as for boyracers just leave them alone racing them won't dampen there appetite for stupidity hooking reverse and backing onto their bonnet will though :roll:
Mud Hog
Post by Mud Hog »
I think the PWR units are well worth the coin!
Image[/URL
GU patrol 35s ect.
slidenyo
Post by slidenyo »
yeah I suppose but I like the true hot rodders approach building something from bits of other vehicles,
as for there efficiency ? probably hard to beat what you have?!
although i'd probably box it so you could fill it with dry ice and further chill your cooling water by running a coil of tube around it before it enters the unit
