Front diff drive axle shaft removal - won't budge!
Posted: Thu Jun 28, 2012 10:37 am
by pjb
Has anyone had any trouble/success pulling the front diff drive axle out?
Apparently it's supposed to knock out with a slide hammer, but I've tried that, no dice.
The interwebs mentions opening the diff cover and levering it out from that end, but I don't think there's any point trying that on mine since the ARB diff carrier is pretty closed up (no access).
Would like to avoid having to take the whole diff out.
Re: Front diff drive axle shaft removal - won't budge!
Posted: Thu Jun 28, 2012 10:56 am
by churchill
I think the circlip on the end of the shaft might be jammed. That's all I can see holding it in. Have you made sure there's nothing else holding the outer bearing in place?
If the circlip is jammed either smash it harder with the slide hammer or try pulling the diff apart...
Posted: Thu Jun 28, 2012 11:48 am
by pjb
I just had a thought.
The outer bearing (opposite end to diff) is a sealed-ball-bearing type, that is pressed on to the shaft, and slides into the housing. Apparently (I've just read), these are prone to failure. So chances are this bearing has seized into the housing. The only thing that locates this bearing is it's position on the shaft, and the circlip that holds the shaft.
So I might try levering and hammering at the same time. With a bit of luck, the bearing will shit itself and leave the outer race behind and let me get the shaft out!
Posted: Thu Jun 28, 2012 11:53 am
by sibainmud
Set fire to it :lol: :lol:
Heat the housing to release the bearing.
Want a hand?
021 742228
Posted: Thu Jun 28, 2012 12:49 pm
by pjb
Cheers Simon!
You wouldn't be the first person to suggest that, but it's usually related to the three red diamonds on the grille... :lol:
I'll give it another crack tonight, see what happens.
Posted: Thu Jun 28, 2012 2:42 pm
by NJV6
Is this on the passenger side where it goes straight into the diff...?
Mine has always pulled out, sometimes taken a few goes but never needed force...
What did you break...
Posted: Thu Jun 28, 2012 4:59 pm
by pjb
Nah, it's the axle on the drivers side that goes inside the axle tube, DOJ connect to it. Passenger side came out pretty easily...
Originally I was pulling this all apart so I could change the diff mount bushes (which are knackered). I had a hard-to-reproduce grinding noise in the front end under heavy load, and thought that perhaps holding the diff down properly might go some way to fixing it.
Since then I've concluded the noise is from the sealed bearing that carries the outboard end of the driver-side inner axle shaft. They live outside the safety of the diff...
Posted: Thu Jun 28, 2012 5:03 pm
by NJV6
Oh that one, I have never pulled my one out. Opening the diff won't work I would have though because there is the free wheel super select piece in there.
Posted: Thu Jun 28, 2012 5:04 pm
by NJV6
I imagine you'd have to unbolt the freewheel piece. Can sent pic's if you want from when I pulled one apart to see how it worked...
Posted: Thu Jun 28, 2012 5:14 pm
by Tarmac
If in doubt give it a clout, the bigger the doubt the bigger clout 8)
Posted: Fri Jun 29, 2012 11:29 am
by pjb
Bashed harder, came out.
Not pretty either. Full of mud and crap - dust seal is goneburgers, and the outer bearing is pretty flogged out. Time for a clean-up.
Posted: Fri Jun 29, 2012 12:18 pm
by NJV6
Shoosh, mine is fine I'm sure..... Should I do it as maintenance given its done 8 years of underwater/mud antics?
Posted: Fri Jun 29, 2012 4:21 pm
by pjb
I'd wait until the bearing unit on the outboard end of the shaft dies. It's outside the dust seal anyway, so renewing the seal won't extend its life.
I also noticed the receiver cup that sticks out of the freewheel clutch is pretty wobbly, so I suspect the bearing on that is on its way out too.
Posted: Sat Jun 30, 2012 11:38 pm
by MNC
pjb wrote:Bashed harder, came out.
Bigger hammer - it is always the answer :wink:
