1992 isuzu mu
Posted: Thu Jun 28, 2012 3:59 pm
by oljamesyboy
hey all as i sold my zuk about a year ago been craving another 4x4 since
iv been offered a isuzu mu for cheap and was just asking pros and cons of them anything to look out for and are there known for any sort of engine issues.
its just clocked over 200k
3.1 turbo diesel
thanks
Re: 1992 isuzu mu
Posted: Thu Jun 28, 2012 4:12 pm
by Crash bandicoot
leaking power steering system, leaking rear main seal .......these are common on the pre 93 models, don't be alarmed if there is oil around the sandwich plate between the motor and box, the last one i had leaked but still clocked up half a million kms. i was the uptenth owner.
the power steering box can leak, this is a WOF fail, i was poor at the time so remedied mine by using diff oil, so thick it wouldn't leak under pressure anyway. also makes a great steering dampener.
Re: 1992 isuzu mu
Posted: Thu Jun 28, 2012 4:14 pm
by Crash bandicoot
some do have injector pump failures aswell, but it is non specific to any particular production of MU's Wizards, bighorns and rodeo's i think its more to do with servicing then manufacture designs
Re: 1992 isuzu mu
Posted: Fri Jun 29, 2012 8:17 am
by oljamesyboy
cheers for thats
went and had a look but needs quite abit of work so ill keep looking
Re: 1992 isuzu mu
Posted: Mon Jul 09, 2012 7:44 pm
by octanepwr
Does diff oil really work as PS fluid? Mine leaks i just make sure i clean it all up before wof. Can u mix diff oil and ps fluid so that it isnt too damped? Or do they not mix properly
Re: 1992 isuzu mu
Posted: Fri Sep 28, 2012 3:41 pm
by wyclef
I do apologize if my post here is quite late. Anyway, 92 isuzu mu is a great 4x4. Most of the pros and cons were already mentioned and for me, that enough information for you for the mean time. The only thing that you need to know is that if aftermarket parts of isuzu mu for 1992 model was still available in most auto parts shop so that you will not a hard time for its maintenance.
