can i?
safari_mulisha
can i?
Post by safari_mulisha »
remove my rear sway bar?
i know a guy with a safari that doesnt run one even on the road
it should be ok right?
it will effect my steering alot of i touch my front one aye? as in heaps of body roll
nuts
Location: somewhere arround westcoast offroading usually
sway bar
Post by nuts »
i know a few ppl that dont run either of them ya do get more body roll tho :wink:
mudchuka
Post by mudchuka »
i havent run a front swaybar for 2 years, i have left the rear one in it disconnects anyway} it depends on how much road work you do, take the front one off and try it, if its no good put it back on.
DaveM
Post by DaveM »
I have removed front and rear, with a 3" lift. No problems, as long as you dont dive it like its a skyline :wink:
safari_mulisha
haha the skyline cant goto burger king because it gets stuck in the driveway
we had to make ramps to get it outta my driveway and i swear if u drove over a $1 coin you would be able to feel if it was heads or tails
matwelli
Post by matwelli »
removed both on the paj, no dramas, just treat the 55 kph corners with respect, met up with a guy in porirua last weekend (was picking up my swampers) with a safari, who also runs without either front or rear bars.
As everyone says give it a go, nothing to loose, lots to gain (articulation) :D
Mathew - 021 441 043
WACKO
Pyro
Post by WACKO »
i removed both of mine, its fine, just dont try to race around, go further not faster. :D
mercutio
Post by mercutio »
i've removed the front swaybar on the wagen when i took it for a test drive i drove another g wagen he had there and it obviously didn't have an anti roll bar on it it wallowed all over the road made it great for the rough stuff though pity the gearbox was totally impractical for the motor or i would have looked at it a little more seriously
DieselBoy
Post by DieselBoy »
Contrary to popular beleif, removing the front sway bar does bugger all to your road handling. mine didn't even have one on from the factory, nither did my dads LWB.
Removing the rear is what makes the difference on the road.
So get rid of the front one and use the factory dissconnect lever for the rear.
