1uzfe serpentine belt tensioner and idler
hiluxsurfer
Post by hiluxsurfer »
I'm after a serpentine belt tensioner and idler for my 1uzfe that I have put into my hilux, my idler is bent and my tensioner is cracked and the spring has gone sloppy inside it. I 've tried toyota and this is now a surplus part, also tried a numorous amount of wreckers around auckland. Does anyone know where I mite be able to track one down?
Dan
jonossiksilvia
Re: 1uzfe serpantine belt tensioner and idler
Post by jonossiksilvia »
not 100% sure but the 1jz and 2jz engines use similar if not the same tensioners
hiluxsurfer
sweet cheers man I'll do a bit of research
Re: 1uzfe serpentine belt tensioner and idler
I might have some parts here, can you post up a photo of it?
hiluxsurfer
Managed to find a guy on tm who has one for a good price but thanks heaps for the help. :D
