But what is around the maximum length shock you can fit in the front with the standard push-pull steering? I know I know I should just measure, but by my measurements I get about 440mm with the shock disconnected (only about 20mm further than the standard shock!), but other reports suggest even upto 490mm. Now I thought it maybe the torque rod stopping it from dropping further as it currently has horrobly unflexible springs. New springs should have been here on Monday, so have to chase those up..again.
Anyone have any further input? Apart from go crossover
