˙hi
I have a 80 series vx with a 1hdt with åround 200km on the clock
It uses no oil or water
I bought it a few months ago, it has been modified a bit with a lift and some š35 inch tires
It accelerates really well but is smoking from hard acceleration, at first and second it leaves a small cloud. I was told it had been tuned, which it probablz has but the smoke and the 6 kilometers per litres is concerning
I am currently travelling around the south island, doing the not main roads and 4wd tracks open, with a czech girl, living in it, or camping nearbz or doc huts, so i cant have it off the road for to long being looked at.
Im in westport heading dfown to christchurch in the next week, id like to get a opinion or two about it, if its just over fuelling, or more serious problem, id love to get someone with a bit of +hdt or diesel experience to have a quick look over before i send it back to diesel an turbo in wellington an cut the trip short . have onlz got as far south as westport in two weeks. with a few months still planned
so if you can recommend a good shop or could take it for a quick spin id love to hear fréom you
ps also keen to go out on any familz-shinz type group trips if any are going in
mike
0276967752
help ˙˙80 series smoking
Re: help ˙˙80 series smoking
Those first few puffs of smoke on hard acceleration can sometimes be caused by turbo lag, it's normally unburnt diesel. And if it's not using oil, I wouldn't be too worried. I'm no mechanic though.
- crazyclark31
i asume its black smoke your talking about?. If it is then its most likly that it needs the fuel screw wound back abit.
- Mr Mumbles
yep black
ps if your from christchurch you might recognise the vehicle
any idea of the history of it will also be good, cheers
"Tuned" may mean someone has just wound the fuel up to the max
Maybe take it to a specialist diesel workshop and get them to check and adjust the fuelling
- zephyrheaven
Heard good things about kaiapoi repowers in Canty for tuning of these monsters, mine should be there in the next wee while - mine has the usual unburnt smog at idle when hot - but I need more powerrrrrrr
Hi there
I know this truck i have worked on it previously at my last job 4x4 accessories,am now owner operater at Kaiapoi Repowers Auto & Exhausts we specialise in diesels and are able to help you out,i dont know any history of the tune been done or what not but are very willing to look at it and take care of ya.
if you give me some warning as to what day your coming down to chch then we can arrange time to view,
or call us on 03-327-5317 or 027-286-5492 ask for Nathan or if im not availiable talk to Cori.
Hope this helps
p.s that vx has had mega dollars spent on it as you would already know!!!
Hope this helps
as above post, go See Nathan, he'll sort it out
Who knew Prados could fly?
- Mr Mumbles
Thanks floor the replies will be sure to check in to kaiapoi when we get in
