I just got a 91 surf with a 1uz + 5 spd conversion, Engine goes great
What are the things i should be investigating? master/slave cyclinder, gearbox syncros, clutch itself, all of the above. anything i'm missing?
Thanks
Sadam_Husain wrote:yep as above sounds like clutch linkage/adjustment/pushrod/master cylinder/slave cylinder etc sort of problem
Big wrote:Sadam_Husain wrote:yep as above sounds like clutch linkage/adjustment/pushrod/master cylinder/slave cylinder etc sort of problem
Sharp as a tack..
tweake wrote:could just be a seized spigot bearing.
nztimr33 wrote:tweake wrote:could just be a seized spigot bearing.
Could be but you'd want to check the rest first - not just jump into pulling the box out to find nothing conclusive.
KotangKort wrote:Thanks heaps for the flow of info guys, talked to the seller yesterday and he said he replaced the slave the day before it was picked up so he reckons he may not have bleed it properly, also reckons that if it's not that then the master has probably had it as its done alot of kms.
All the advice i was given in this thread i passed to my mech dude.
I still dropped it in to be checked ova this morning BUT when i jumped in (ready for a war) to take it down it was fine??!?!?!![]()
Everything seemed to work fine, every gear slide into place??? It's like nothing was wrong in the 1st place I'm totally blown away/f@#$n stoked by it.
It was parked outside in the frost this mourning, could the cold have had an effect? That's the only difference i can think of.
ClassicCruiserSpares wrote:I heard through the grape vine its all sorted now yea? Sounds like whoever mounted the slave cylinder put it on the wrong angle and also the pipe into the slave cylinder was leaking everytime you put your foot on the clutch.
