water crossing cut out
where is the sensor mounted that turns off the electrics during a water crossing mine has activated and wont turn off so my battery goes flat!
Re: water crossing cut out
I don't believe there is any sort of sensor...
More like you have introduced water into some of your wiring or controls modules / relays and its shorting out.. Hence the battery drain...
