Hi All
Winch challenge truck is on the way and this has to go.
I've owned the zuk for almost four years. I bought it off trans-rail, I'm unsure of actual k's but it seems to have been well maintained. When I pulled the rear diff out to install locked it looked brand new.
I hydroliced it the first week of owning it so it got a new motor, clutch and some other bits.
Very recently it had the front knuckles rebuilt.
All oils have also recently been changed except engine oil which probably has 2000km on it.
-50mm body lift
-Front winch bar
-Rear steel bumper
-5000lb warn, oldie but a goodie. Control box is on the firewall with controller in glove box.
-Near new 30x9.5x15 kumo KL71 mud terrains X 4 (Maybe 6 outings, sharp edges still) on custom large offset rims. (hard on wheel bearings and can be swaped to normal steel rims if you like)
-Sj410 transfer case with crawler gears
-2 month old 600CCA battery
-Alternator reconditioned 2 months ago
-Rear locker, went in 4 months ago (Chinese)
-Fuel filter 2 months ago
-Has inline back up electric fuel pump on switch
-New clutch bearing 2 months ago
-New rear brake shoes 4 months ago
-Extended breathers on both diffs and transfer case into cab
-Has cargo barrier, no rear seats
-New drivers seatbelt 4 months ago
-Cargo Barrier
-Carpet is long gone
-Rear seats are to.
Comes with
Rear disk conversion brackets + callipers and disks etc
Transfer case drum brake for handbrake if using rear disks
Set of four 15in rims. Good offset.
Set of 5 all terrains for wofs
Bad points
Snorkel is fibre glass - Can supply plastic one in about 8 weeks for $100
Flairs are fibre glass, I haven't managed to break either yet so reasonably tough.
Behinds the flairs the front guards have been hammered back. With the big offset wheels it will fit 30s with normal rims id say it would fit 32 or maybe 33s.
Passenger's side front brake hose needs new bracket or new hose due to body lift.
Surface rust around windscreen needs touch up before next warrant.
Gear box has wine, last one had louder wine for 3 years before it became too loud to put up with.
Small exhaust leak
Usual dings
$4500
Tom
027 2044 866
