Hey folks looking for an old air compressor tank, any condition as long as its made from steel.
preferably 30cm diameter, but bigger would be better.
around 60cm in length would be awesome but longer will be fine.
just after the tank itself, nothing else,
if you have something similar like a steel cylinder i might be interested aswell.
WANTED: Air compressor tank
Re: WANTED: Air compressor tank
Where are you? I have a couple of old air tanks off of a truck here
down southland area, in gore..
go to ya local dump and look around the recycle area, by the lpg gas bottles. i picked up a fire extinguisher for nothing.
easy option
easy option
I got one you can have for a box,if you can be bothered coming to get it..
650 x 300 odd ?
queenstowns a bit far away, unfortunately
ill see what I can do..
- bob_or_jim
Next time your at supercheap ask them if they have any returned compressors out the back. I did this and got a 25 litre tank that was brand new. They just rip the motors off them and scrap the tank.
Hope you find 1.
Hope you find 1.
cheers for the info, looks like il be getting one from Big
If you can get to invers i could get you one 4 free will just be the small repco super cheap direct drive motor style compressor tank roughly 300mmx600mm?
invercargill is definitly closer, ill see when the next time i am going down is and get back to ya
