correcting front axle angle?
Posted: Wed Jul 18, 2012 2:23 pm
So im about to lift up the suspension in my d21 navara and am worried that im going to have the same issue i had with my ln130 , this being the extreme axle angle and therefore numerous cv replacements
So ive been lying under there having a look at the possibility of making brackets to lower the front diff case down the only problem i can forsee is the mount thats on the front of the main case , im wondering if anyone has attempted this before and how they went about it. Also will moving the diff down 60mm or so require an extension of the driveshaft? and would i then run into issues with uj's wearing out quickly?
