Hey guys,
Friend of mine is having issues with his 3.1L diesel bighorn
He was out hunting and managed to short out his alternator and melted a few wires and blew a couple of fuses.
he has since replaced all the blown fuses, and it has started cutting out since.
its hard to say if it is linked, as it was going fine for a week or so and then cut out.
Im partial to say it could be a relay somewhere? but which one would be a good question.
Well looking foward to see what you folks have to say,
Tristan
isuzu engine cut off while driving
- mud_slinger
Re: isuzu engine cut off while driving
is the wire in his fuel cut off solenoid loose? mine was and every water crossing it would cut in and out.
needs more curry
0272593533
0272593533
ill ask him next time i talk to him
also check the fuel line sys. as it also has been known to have crap in the tank which blocks the pipe, cause a vac in the line and stops the motor, will it stop when reving in the drive drive way, if so watch the filter primer to see if it get sucked down? where in nz are you?
Down in southland.
The clogged fuel pipe happended to me but this seems differrent. Its a sudden cutoff as if the key is turned off.
- mud_slinger
pressy wrote:also check the fuel line sys. as it also has been known to have crap in the tank which blocks the pipe, cause a vac in the line and stops the motor, will it stop when reving in the drive drive way, if so watch the filter primer to see if it get sucked down? where in nz are you?
hmmm wonder where that situation has been seen before
needs more curry
0272593533
0272593533
